Preventing squeaky floor while off-roading?
ElizaDolittle
I know it's awful to think about scrapping something you worked so hard on.
I hope some more people will weigh in here, maybe after the holiday. I KNOW I have seen other references to foamboard under floors causing squeaks, but I ran a bunch of searches last week, here and on the sportsmobile forum, and could not find the threads.
I was looking because I am about to start the floor on a new build and I wanted to learn from those who have gone before! And maybe they could help you, too.
Ozarker
Marsaa111,
You did a fine job, nothing wrong with your craftsmanship, that's good! The suggestions and comments I made wee to the design, no squeaks, secured, economical use of materials that function.
IMO, many DIY builds are over built, there is more wood used than really needed, that adds additional weight, your's isn't bad in that respect, but another aspect is over insulating......many might say you can't have enough insulation, but really there is a very marginal difference that becomes a cost/space/ benefit matter.
I was in a stock van years ago in upstate NY, 52 degrees below with wind, the floor was carpeted and had a heavy rubber mat that went wall to wall, we used a aux gas heater and it burned us out of there, we crack windows for safety and to keep condensation down.......we were warm peeling off the winter gear, even taking our spit bath.
An example too, we'd dig a snow cave about 3 feet deep, lay a tent floor and pack snow around the tent. You're laying on top of snow and with a small sterno stove you can be warm with a good sleeping bag. Cold doesn't rise, and when you break that camp you'll see an icy floor. Dampness is the enemy and staying dry is the priority.
I have found that it's not so much the cold we have to insulate for but the heat, if you're going to over insulate a vehicle start with the roof, then walls and windows, the last issue is the floor.
A vapor barrier is to reduce air infiltration and allow management of condensation, consider reflex glued in place that does a good job of keeping the desired temp.
In a vehicle, every inch you build inside takes an inch away from usable space and in a van, space is usually limited.
The hardest areas to insulate and cover are doors and windows. Weather stripping can help at the door jams, might make you pull harder to shut the door too, which is good, that means you're getting air tight. Lots of ways to insulate a window, you could go with expensive coverings or blankets work too. Hot or cold, these are areas to address. IMO
Most say not to use spray foam like Great Stuff in a vehicle, I agree it traps moisture and can cause rust later on, however, there are spots where it will work without issue. Light fixtures on ceiling and upper walls, wiring holes like tail lights, door handles and a bit around wiring grommets. Not globs of it but spots of it, I put some on a paint scraper and spread it in when it's freshly sprayed, like butter and smooth it out. Any area you use this stuff should be visually check annually for any issues. Interior holes are less of a rust issue and keeps air from moving through framing of inner and outer skins inside. Other products light insulation pads for home outlets can be adapted and then there is always duct tape, LOL. Stop the air drafts.
My GF had a custom van conversion company, these trick or opinions come from experience and I've built a few vans as well, Ford, Chevy, Dodge and VWs. Spend time with the 10th Mountain Division and you'll learn about cold, LOL. :) .
mrsa111
I had heard about foam board in the floor causing squeaks too, which i read was from it being sandwiched between two layers and it moving around between them. I'm HOPING my idea of using a foam board thats 1/4" thinner than the furring strips will eliminate that, i kind of tested it out when the floor was out of the van, I couldnt get it to squeak.
Im going for a drive today to find some rough roads and places where i can get the van to flex, if it doesnt squeek, i'll keep it, if it does, ill probably scrap it.
Its crazy how much research can go into every little aspect of a van build!
Ancientsojourners
