Technical question on 98 Montero sr
Dima1127
I'm having issues with the automatic transmission in my 98 full size montero (190k miles) the car drove fine all day until the very evening when I went to drive it home, after driving it for half a mile I came to a complete stop and when I started to take off (in drive) the transmission started to completly slip, it will go up to about 3k rpms and barely move a foot. Reverse, 2nd gear and low works just fine. So I'm at a loss here. I assume low is first gear so I'm assuming it isn't the clutch packs, could it be a solenoid? And opinions on help is appreciated.
Sent from my SM-G955U using Tapatalk
Dima1127
If a clutch pack was burnt. Then I feel like low or 2nd or reverse would have issues as well. What do you think?
Previous owner said he doesn't remember what fluid he used
Salonika
Monterror Pilot
Change the fluid and use the spec stuff, then go from there. Cheapest & easiest round-1 troubleshooting you can do.
Dima1127
After a little digging around me and the previous owner did establish that it was oe fluid used. So I'm taking a stab in the dark and ordered some solenoids. Wish me luck boys haha
TheMole
OE fluid meaning SP3 or Dexron. Reason I ask is because the owner's manual in my 98 specified to use Dexron. I noticed the trans shifted way smoother with SP3.
