Ski Bum Truck V2.0, F450 Rough Road RV
Healeyjet
Does that booster antenna stay on while you drive? That thing could cost you 1 MPG! :)
I am interested in the performance test of the booster as well as we were looking at doing something like that.
Ward
java
Ward
It does stay on, not too hard to take on and off of desired though. There is also a tiny mag mount that comes with, but I figured I would try the big one first!
I'll let you guys know how it goes. It's a WeBoost 4G-X, formerly Wilson.
java
A quick weekend in the woods.
"fixed" the broken and rattling running board. LWB problems....
Need to check tire pressures, but it felt much nicer this time, I think the rain and traffic filled in a lot of the holes. Washboard was no problem at 30-40mph, the big holes were still jarring if you didn't slow down in time. I rattled one of the lights loose, fixed that yesterday.
java
Looks like a good, quiet camp spot
Its a great one!
One more quick project down. I needed better access to the propane tank. I had a 6" deck plate in the tool box, it was enough to turn the gas on and off, but not fill the tank, I had planned on a remote fill (and may still do that) but I couldn't even get the remote fill parts hooked up without dropping the tank.
Sooo in comes a bigger hole.
Round corners dont crack as easily.
Annnnnd door.
Much better access, I am going to ask my local fill guy if he can work with that rather than the remote fill....
java
Thnaks guys!
If anyone sees any genius solutions for hooking up a high pressure T for outdoor stove let me know.
The normal ones are too long for me to fit with the regulator on there.
V45W_Proto2.5
