Speedometer and Odometer not functioning
MrGalantguy
Mitsubishi Loyalist
Like the title says...both stopped working last Friday going to work. Speedometer would work normally then start the needle would go all over the place on the way to work and when I went to go home it continued to do the same and halfway home it just stopped working all together. I looked through the FSM a little bit this weekend but will have to look a little more but I called Mitsubishi today and they say there is are Vehicle speed sensors on the transmission.
Has anyone had this issue before and how you diagnosed the issue? This is on my 98 Gen 2.5 btw.
Saguache
Very likely the speed sender. Pretty easy part to replace on most vehicles, but I've never had to do it on a MMC
Sent from my Nexus 6P using Tapatalk
Linesman1776
