Anvil 2015 JKU Sport Overland Build
Outside somewhere
Overland certified public figure brand ambassador
Wow! :eek:
Very cool rack! :beer:
Looks like you could park another Jeep on top of it.
Not a jeep but
https://www.youtube.com/watch?v=X4_m5Nfsr-g
As they don't give any specs on what it's truly rated for I was curious. After talking to people in the US and elsewhere I figured 1000 pounds was safe. I put the RTT on (tepui gran sabana/annex,180ish pounds?) and put myself and two buddies (another 660 pounds) on the rack and in the tent. Then put two loaded pelican boxes (another 150) on the front of the rack side by side. There was no bending in the rails at all and that's with just the slats the rack comes with so I'm a happy camper.
406to417
I was thinking of adding the breather kit but was going to run it into the air box. Where you mounted it is great!
Yuke
I have some updating to do!
This Photobucket hosting nonsense has really thrown a wrench in the system
Comanche Scott
If your build thread is only on this forum, you can use post them right into here.
You could still do it, even if your build is on multiple forums, it's just a duplication of effort for each forum.
I like doing this, because the pictures are always right here. So if someone asks a question in another thread, I can reply and snag a picture from the file here to post real quick. :)
Yuke
Where did you hard wire these to, directly to the battery?
For the rear, its actually wired to one of my two switch pros setups.
For the front, quadratec makes a nice plug and play 12v splitter for the front outlet. Its pricey for what it is, but save you from splicing factory wiring.
Robbi Smith
So you have a switch pro in the rear of your Jeep? Do you have any pictures of this setup. Thanks.
V45W_Proto2.5
