Solar Charging questions
SoCal Tom
Now that I've joined the Solar cult and spent some money I have a few questions/assumptions...
First,
Everything I read about battery charging says that it takes 12 to 15 hours to fully charge a battery http://batteryuniversity.com/learn/article/charging_the_lead_acid_battery
Since the sun doesn't provide 12 hours of light most days, is it safe to assume that you won't charge your battery back to 100% on solar in most cases?
Next, I've got a cheapy amazon solar controller. Battery charging is full recharge until the voltage hits a programmable cutoff ( I've set it at 14.2), then it just maintains it at 14.2 ( 2.35v/cell). When I get home I plug it in with my fancy converter and it tops off the battery ( and does some anti sulfanation stuff) Does this seem reasonable?
I know I can get an MPPT that has the three stage charging, but when will you ever get to stage 3?
Now, I'm running a walmart marine/deep cycle 85AH battery. The last one lasted 5 years. ( about 2 months past the warranty). I've been reading a lot about depth of charge and cycle impact. If I assume that I'm camping every weekend for 5 years then I would have 2 cycles per weekend (520 cycle lifetime). Given the limited life of the battery, I shouldn't impact the life of the battery if I discharge it to 75 or 80%.
Did I get any of this right?
Thanks
Tom
john61ct
That site has a lot of misinformation, check other sources too.
If your power( wattage ) is enough, 5-7 hours can get to 100% Full from empty (50%)
john61ct
As long as you consume less than you put back no problem.
As long as either you only go away for 2-3 days.
or replace your batteries mire frequently.
john61ct
No that will murder it much faster than keeping to 50%.
From Sam's Club or Batteries+, get a pair of flooded 6V Duracell GCs, maybe $180
Will last much longer, cheapest possible actual deep cycling per AH.
CaliMobber
Kinda a long read but prob the best place to learn about prober solar charging of batteries.
https://handybobsolar.wordpress.com
You can charge you batteries 100% one one day I do it all the time. Just depends on how low you drain them. after 80% they charge much slower so need more time than say 50-60%.
You have to ditch that cheap amazon controller to get proper charging.
SoCal Tom
Thanks for the feedback. I'll probably just run with what I have until this battery gives up the ghost in 4 more years. Then it will make sense to upgrade to MPPT and the better batteries.
Tom
Step-Hen
A quick, back-of-the-envelope calculation: If you run your 85Ah battery down to 50% each day, you'll theoretically need 42.5 Ah of solar charging per day. Factor in charging system inefficiencies, and call it 55Ah. If you have 5 sun hours (not hours of sunlight) per day, that means you'll need 11A out of your solar panels. 11A * 18V= 198W of solar. So, 2x18V/100W panels would charge your battery each day. You have to factor in that the charging current will taper off, but if you do you bulk charging early in the day, the solar panels should have enough time at reduced output (late afternoon/evening) to top off your batteries before sundown.
SoCal Tom
My math is a little different. Assuming I need the 42.5Ah at 12.5V, then what I need is 531Watts. Assuming the 5 hours of "Sun" hours , I would need 106 watts of charging per hour, add in the 30% efficiency losses now I need about 140 watts worth of solar panels.
My question isn't so much about whether I can push back the required amps into the battery, but more about whether the chemical reaction in the battery can happen effectively in that time frame. Smart battery chargers hold the voltage for many hours to get the battery to 100%, so why would they do that when they could accomplish that in just a few hours?
rruff
I've heard the same thing. Lead acid batteries require several hours of low amperage charge to get from 80 to 100%. 50-80% you can do quickly. And if you don't get them to 100% on a regular basis they wear out.
One reason I'm going with LiFePO4.
dwh
Tail-End Charlie
The "2x18v" is a somewhat dubious assumption.
With a PWM controller, the operating voltage of the solar would be battery voltage, which will be quite far below the solar panel's Vmp.
With an MPPT controller, the solar would be operating at Vmp, but the output to the battery will be at battery voltage.
So...
85ah battery down to 50% SoC - 42.5ah. Batteries are not 100% efficient, so to recharge 42.5ah, you'll need 42.5 x 1.2 = 51ah. Divided by 5 hours good sun, around 10a/hr into the battery.
At battery voltage.
Which will change over time as the battery absorbs energy and builds up a surface charge on the plates.
So say 12.3v to 14.6v. 2.3v difference, let's split the difference and use 13.5v for estimating... 13.5v x 10a = 135w. So with an MPPT controller, 150w of solar would get it done. With a PWM controller, the solar Vmp might be 18v, but the solar is actually operating at 13.5v (average over time), which is 30% below Vmp, so let's say 135 x 1.3 = 175w to get it done.
(Actually, that's wrong, but I used it to show a common mistake... yes 13v is around 30% lower thsn 18v - BUT - 18v is around 150% of 13v. So 135w x 1.5 = 202w is correct.)
But that doesn't answer the original question about absorb time...
The answer is: it depends on the voltages, which are variables.
If you bulk stage the battery to 14.4v, the bulk stage will be shorter than it would be if you bulked to a higher voltage like 14.8v. But at 14.4v, the battery is less full than it would be at 14.8v, so the absorb stage is going to take longer if you switch from bulk to absorb at 14.4v than if you switch from bulk to absorb at 14.8v.
It's not a 1:1 correlation. Bulking to a higher voltage might add an hour or two to the bulk stage, while shaving 3-6 hours off the absorb stage.
Different batteries have different voltage limits, specified by the manufacturer. My pair of 200ah Chinese AGMs specify (printed on the side of the battery) 14.7v bulk, 14.7v absorb.
Basically, any lead-acid battery can be taken up to 14.6v-14.8v AS LONG AS you don't let it get hotter than about 125 degrees Fahrenheit.
Flooded lead-acid batteries will of course use more water when taken to higher voltages, but that's a small price to pay for shorter charge times and increased battery lifespan.
Sealed lead-acid batteries, such as AGMs just need to be kept from momentarily opening the popoff valve and losing irreplaceable water.
My Victron MPPT is set to 14.7v bulk and 14.7v absorb. When it detects life from the solar panel (sun is coming up), it measures the battery voltage and uses that to set a max time limit on the absorb stage. Once it enters absorb stage, it will continue until the amps flowing drops below two amps, or the timer elapses, whichever comes first.
But no matter what, absorb stage will end when the sun goes down.
Shore power chargers are usually conservative. Lower voltages, which takes more time, but time doesn't much matter - shore power, unlike solar, doesn't have to get the job done in 8 hours or less.
SoCal Tom
So...
At battery voltage.
Sealed lead-acid batteries, such as AGMs just need to be kept from momentarily opening the popoff valve and losing.
I appreciate the input. I actually use about 300 watts per day, at 12.5 volts that is about 24 Ah, With the 1.2 multiple for charging efficiency I need 28.8 amps from the panels. Assuming 5 hours of sun, that is 5.76 amps/ hour of charging ( at above charge voltage). My panels are rated at 5.72amps, so if I get anything over the 5 hours I should be fine, if I don’t it should still be several days before I get into a sub 50% situation.
Tom
SoCal Tom,
If you really want to know how much "energy" (Watt Hours) you're using and what your solar charging system is providing on a typical day, I suggest you invest in one or two of these devices...they're cheap and they work.
https://www.amazon.com/bayite-6-5-1...coding=UTF8&psc=1&refRID=6T3PPZQGGRNZGR2JRERC.
I put one on the feed from my MPPT controller to the battery and another on the feed from my battery into the camper. In addition to showing voltage, current and instantaneous watts, the unit logs watt hours, which is the most useful unit of measurement if you want to see if you're running an overall power deficit in your system over the course of a day or several days of varying solar conditions.
On a recent weekend over in Alabama with mostly clear skies, I would see about 1000WH of power from my 2x100W Renogy Eclipse panels into my system. At peak sun during the mid-day, I will occasionally see 160w-170w out of my 200 watts of panels...but this level is only achievable if I tilt and orient the panels to the sun...will never see that with them flat...at least not in this area. You will probably have a better output in SoCal.
Another factor to consider over the course of a day is when you're using your power vs when power is available from your solar system to charge the battery and supply any necessary power requirements during the day. You may find yourself going below 50% SoC overnight, depending on timing and amount of power required.
SoCal Tom
SoCal Tom,
Thanks, I ordered one. I've estimated use per hour for each of my power using devices, using the load ratings on the SCC ( solar charge controller), and last trip my estimates pretty much lined up with the expected battery voltage the next morning, but it would be nice to know the exact numbers. If it gets here soon enough I can wire it up before the next trip. Buying 2 isn't in the budget, so I'll probably monitor the load this time around, and then move it to the panel side after that.
Tom
calicamper
This may be of interest it gives you an idea of the impact season has.
This is one LG 285watt panel report July vs Nov. I have 29 panels I can see each panel stand alone or the system as a whole.
This site is also a great tool to get a pretty good sense of what your location can produce.
http://pvwatts.nrel.gov/pvwatts.php
project13support
