Hi-lift / shovel box for roof rack
maxi450x
Under construction.....the idea is to keep it clean and dry out of the suv
Enviado desde mi S60 mediante Tapatalk
theblindchicken
Looks cool! Putting clamps or brackets on the inside to secure them, yeah?
Maybe try adding a quick bolt on fairing for the front to help keep drag and noise down. Make it adjustable so you can tune the best angle for it.
maxi450x
Hope it doesnt drums on bumpy roads, the hi-lift isgoing to be bolted resting on rubber blocks and the shovel straped, in theory it's Going to be quiet
mep1811
Gentleman Adventurer
The high lift will be fun lifting out of the box while balancing on your tire or door sill.
tarditi
install some quick fists inside for the hi-lift and shovel - they'll keep them secure and rattle free - can also leave some room for recovery straps, gloves, etc. Nice job.
krick3tt
Great idea, especially for carrying the stuff all year. Since you are probably a young guy lifting it out might not be an issue for you.
Might even fit in a fishing rod or two.
Wilbah
I like it. Was going to ask about lining it with a thin rubber mat to keep noise down of anything loose. I like it.
krax
Any idea how much it weighs? I was looking to use a Pelican rifle case for mine, but that's 20+ pounds of roof load with just the case.
JIMBO
:sombrero: You could use a "JACKCASE" from Quadratec-I've had mine for over ten years and used it on top/inside/on the spare tire-the case weighs about 2lbs, until you put that jack in--then--about 30lbs--too heavy for the tailgate on a jeep !
You'll always have to be careful using anything on top--holding the HiLift--that's a heavy hunk of steel
Good luck
:sombrero: JIMBO
maxi450x
2/3 LBS box+ hi-lift+ shovel+ 8ft 3/8chain + offroad kit+ 30mts straps
maxi450x
Good luck
:sombrero: JIMBO
That case looks Nice, here in Argentina we don't have them
maxi450x
Finished product, in addition mounted and wired a 500w led bar and some led stripes for the trunk
gp01
