robert
This what I carry with extra stuff in it. https://www.extremeoutback.com/product/27/The+Ultimate+Puncture+Repair+Kit+Part#+001-009.html
The long tire irons are harbor freight and the short ones are motorcycle. The glue and talc came from Nappa and if you want to carry a tube then just make sure the stem is in the right position and not the real fat truck stem. The best bead breaker I've found is the hi-lift Jack. They are a pita to lube up and use but nothing beats it for breaking a bead. Watch the you tube videos on breaking down and mounting tires and practice if you get the chance. It's impossibly hard if you do them wrong and fairly easy once you know the trick. I think I could change a tire with the motorcycle irons if I had to.
The other rear tire had a cut in the tread area that needed to be sewn today so now both tires are sewn. Previously a stick went thru it. I could only get inside the tire thru the beadlock ring so I wrestled my arm in enough to put a tube patch on the tire then installed a tube. Tube patches are only thin rubber and it bubbled out. Tire patches have cords in them. If you noticed in picture of the patch it tells you what way position the bead needs to be lined up. There are different patches available for bias and radial. Our local Tractor Supply Company had both but the biggest patch said bias tractor use only. Not sure any of that matters in a pinch. The brand they sold was Slime and they worked great. I'm going to beat both tires for 4 days and plan on doing a poker run on Friday. I'm only going to run 14 psi so that ought to be a good test. Wish me luck!
That's a really nice kit you have. Maybe I'm not seeing it but a valve stem puller/insertion tool makes putting in new valve stems a lot easier and they're usually under $10.
Harbor Freight also sells a swan neck bead breaker for under $20 whereas Amazon wants better than $30 for what looks to be the same tool. I've seen them that have a tire lever on the other end so it's two tools in one but I'm sure they're more expensive. https://www.harborfreight.com/automotive-motorcycle/tire-wheel/tire-bead-breaker-with-swan-neck-67403.html
ETA: No, I don't carry as extensive a kit as you do. I only have the small tubes of glue- always carry an unopened one as they dry out over time. I'd also have to use the can of Anti-Monkey Butt powder or Gold bond instead of talc. I'm interested in hearing how your tires hold up though, I can't recall hearing about any high speed buggy runs with repairs so it ought to be a good test.
