teotwaki
Excelsior!
Haha
Good efforts
You win
I kind of figured you regarded this as a must-win situation rather than just a forum discussion where we can all learn and occaisionally get a good laugh.
Haha
Good efforts
You win
Good paper. It is quite systematicI'm no expert in this field, so pardon the dumb question, but I have been doing a lot of reading on this subject lately for my own application. Has anyone ever developed a smart voltage regulator that can mimic a DC/DC charger profile? Most alternators should have more than enough power to charge a large battery bank, it's just limited by the controller (in most cases, the VR). Seems like it would be easy enough to have a microprocessor controlled regulator that can deliver the optimum charging profile without the need for a B2B charger. This would eliminate the need for a step up converter since the voltage can easily be controlled directly to whatever it needs to be.
That is exactly what GM does on the Chevrolet Silverado line. Can't speak to other makes and models.
In the case of Chevrolet trucks, it appears that the alternator has a built in 13.9v regulator which is, in turn, overridden by the vehicle's electrical system as needed. If the on board computer fails, then the charging system reverts to the internal regulator. Works very well, and is one reason why I dismounted a Sterling Alternator to Battery charger (A23B) and simply went with an intelligent relay.
The reason that this thread is degenerating into a food fight is that folk are confusing ends and means.
-- The end is to charge the battery by providing the appropriate combination of amperage and voltage.
-- The source (in this case) is the vehicle's alternator.
-- The means are manual switches, ignition controlled relays, intelligent relays, external voltage regulators or adjusters, independent add on alternator/regulator combos, and, of course, battery to battery chargers. (There may be one or two I missed.)
As someone noted, there is no single solution.
I am updating my paper on this, so read this and please comment: https://cookfb.files.wordpress.com/2016/09/dual-battery-slides-2016.pdf
(And note that I do publish my sources.)
Pm me.Haha
Good efforts
You win
This thread is about dc-dc charger.
Yes, there are many. Sterling, Ample, Balmar, I think Mark Grasser.I'm no expert in this field, so pardon the dumb question, but I have been doing a lot of reading on this subject lately for my own application. Has anyone ever developed a smart voltage regulator that can mimic a DC/DC charger profile? Most alternators should have more than enough power to charge a large battery bank, it's just limited by the controller (in most cases, the VR). Seems like it would be easy enough to have a microprocessor controlled regulator that can deliver the optimum charging profile without the need for a B2B charger. This would eliminate the need for a step up converter since the voltage can easily be controlled directly to whatever it needs to be.
Most can't put out even half their rated power for any length of time without burning out.Most alternators should have more than enough power to charge a large battery bank
Many if not most vehicles these days do not physically have the room.Its getting to the point will be easier and cheaper to fit additional alternator.
I don't know what that means. Limiting current is very important to protect the alt from burning outUse a alternator to charge a battery has no current limitation.
Voltage is critical to proper care of the bank, function of the regulator not the alt.Worth noting in all of this that we are assuming that the vehicle's alternator can produce adequate output, call it 100A @ 12v.
What we are arguing about the the voltage(s).
None of this matters if the alternator does not put out, or cannot be tricked into putting out adequate amperage.
This thread was about...[snip]…
It does seem that there are some individuals on here who want to show how much they know about every little detail about batteries, chargers and related. The nuanced details that they go into are just not a factor in the real world. It seems, to me, like they're just trying to push a sales agenda.Voltage is critical to proper care of the bank, function of the regulator not the alt.Worth noting in all of this that we are assuming that the vehicle's alternator can produce adequate output, call it 100A @ 12v.
Amps are less so, a given alternator can only put out so many for so long, at a given temperature.
Usually the high temps from trying to pull too many amps for too long result in effect **no more charging** at all.
Bringing the amps demanded down to a temperature level the alt can handle is the critical function required
whether handled by replacing with a quality external VR, Alt-to-battery unit, or if a modern Euro-style catastrophe a batt-to-batt charger is required, able to handle almost all scenarios, much more flexibility.
If high amps for long periods is truly required (very rare) then a vehicle that can accommodate a large frame Leece-Neville alt as seen on emergency vehicles is required.
As well as the sophisticated regulation hardware discussed above.
I am sorry that I hurt your feelings baby boyThis thread is about dc-dc charger.
Yes it should be a discussion about DC-DC chargers except 25% of the posts are yours with repetitive attacks against DC-DC chargers or snide remarks about anybody who says the chargers were the right solution.
QUOTE"martnH:
The redarc you want to buy is a little baby
……."hobby" dc-dc you want to buy.
And this is all marketing ****************...
Now the little baby dc-dc will not +be able to do that.
So yeah.dc-dc is a waste of money (in most cases But I will give you that their marketing is pretty good
Especially when ppl buy 25amps baby dc-dc.
Get your facts right.
Some very obvious conflict of interest in this thread.
Think about this. $$$guy
What a waste of our time and hard drive
Will maybe take you 5 mins and save you $100( if you are rich, then it's about your IQ
Nothing is more offensive except personal attacks. (especially ironic don't you think?))
And the idea that most alternators can't even sustain an output when they get hot, is ridiculous. They're rated output is what's listed on them and that is good up through some very high engine compartment temperatures.
