Fold-able, packable 100w solar panel recommendations?
RacerAV
Goal Zero has a 100 watt set up that looks super foldable/packable and pretty rugged. Pricey though!
java
Well... took the plunge and invested in the mohoo from Amazon. It's coming tomorrow. Not sure if I will have the time to set it up before I go traveling (plane not trailer) but I'm looking forward to a 100W panel to slow down the battery drain ;)
First real use of my Mohoo panel this past weekend (more than just hooking it up To see if it worked....) one of the cells like like it Shorted and melted thru the panel. It topped out at 60w according to my Victron meter.
vartz04
I have two 50 watt ones. So far they work as advertised I’ve had them for about a year.
luthj
Engineer In Residence
I have seen overheating and similar damage like that on a few flexible panels. They are much more prone to cracking at the solder joints, and in the cells themselves. I really like the lightweight and portability, but they are no very durable...
Pinnacle Campers
Chateau spotter
I have followed this thread since the beginning and wanted to chime in with the direction I went.
Having a black camper van means I prefer to park in the shade and most of the areas we camp are heavily tree'ed anyways so a portable panel has always been my primary consideration for this application.
I decided to spend a little more money hoping to get a better quality panel that wont end up like the dokio, or the mohoo above.
I chose the Lensun 100 watt portable, https://amzn.to/2sTVcAP
Mine came in a camo bag, sans logo or controller, just two MC4 pigtails. The cordura type bag is super durable, and these are the ETFE laminated panels.
Similar to the Acopower, (linked above, https://amzn.to/2HAvC9f ), the Lensun has a built in stand which makes it easier to optimize output.
As a side note, I completed the system charging 150ah worth of battery with a Victron Smartsolar Charge controller, https://amzn.to/2Hzn42l, this has the built in Bluetooth and works great. I also purchased this 80' 10awg extension cable, https://amzn.to/2l0Fv7q, cut it in half (making it 40'), so the MC4 connectors are on the panel side, and attached a 10g SAE quick disconnect https://amzn.to/2LCvpF4 on the controller side (with a tension relief) for quick deployment.
The 40' of cable coils up in the bag sewn into the side of the panel so I can pull out as much or as little as I need.
SameGuy
View attachment 453746View attachment 453747
Does that controller get hot? I just ordered one, trying to figure out where I can mount it.
off_to
