Hillbilly Heaven
There are two forms of Scepters. One is military that use a non carb compliant nozzle . The other form is the civilian Scepter that has a carb nozzle. The nozzles between the two will not interchange.
Properly maintained the military Scepter tanks will not leak fumes of liquids. If they do leak from the seals it is because they are damaged or need new seals. Most that come from the Military are for diesel. Most of use unleaded and we ruin the seals. If you misuse anything it will wear out faster.Well...now you know to go slow opening gas cans when the altitude has changed.
My NATO steel cans that are 6 or 7 years old remain leak-free when carried on their side, which is my standard procedure in order to minimize vehicle height. Scepter fuel cans...based on the 4 or 5 different ones I owned... leak more vapor than the NATO steel cans, and will noticeably stink up any closed space.
Whose mount is that? I don't recognize the logo.Plastic cans never have this problem.![]()
Otherwise I think this setup is gorgeous BTW
Part #03609I couldn't tell you. It's a coworkers vehicle that's always in the same parking lot as me. But I'm envious of his really great Frontier setup.Whose mount is that? I don't recognize the logo.
Thanks My old eyes couldn't make out the logo.
If anyone is interested, we drew up a wrench like this and 3d printed it in ABS at 70% infill. It works great and I'll give the .stl files to anyone that is interested.This looks like a different design than the normal Scepter one, but you get the idea:
