Off Road Overland Camping Military Trailer - Custom Built!
overlandalex
Took 6 months to build this fully custom trailer. It's based on a 1960's military trailer, completely taken apart and rebuilt from the ground up. Everything was rebuilt with American steel, and all brand new components. I used this trailer 3 times only!
Too much to list but here's a start.
-Timbren axle-less independent suspension
-33" Goodyear Duratrac Tires (3 total including spare with same 20" rim)
-dual bank battery system with charging port
-LED lighting all around
-30 gal water tank with electric pump
-custom 360 degree articulating hitch system
-electric brakes
-custom modified bed slide allows you to pull out entire bed.
-ARB 5 person Roof Top Tent ($2000 cost alone)
-2 canopies
-4 trailer jacks for leveling trailer on all 4 corners
-custom fitted bed tonneau cover
This trailer is built like a tank and solid!
I got well over $20,000 into this thing and that does not include my labor, figure it would cost at least $25,000 to build something like this from scratch. I'm letting it go for $15,000 or best offer!
Clean title and inspected, ready to go!
overlandalex
Where is this trailer located and what is the approximate weight?
thanks.
I have to get an exact weight because i never officially weighed it, but i think its around 2200-2500lbs. I can reduce the weight of it by removing the bed slide which is approx 300-400lbs, i can remove a few unnecessary things to lighten it up. I was also considering cutting down the overall height of the trailer to make the tent easier to set up.
Trailer is located in West Babylon, NY 11704.
Thanks, Alex
Thorgrimr
Hi!
I am very interested in your trailer and I think it is a gorgeous build, do you still have it and did you every weigh it?
4xCoffee
