2006 Fx4 Level 2 Ranger
autism family travels
Love the new rig bud! I thought about getting one of those too, but the lack of back seat space keeps me from getting one. They have the side mounted seats correct?
UltraHDGames
Thanks! and yes you sit sideways in the rear seats, not really great but it works in a pinch or a 15000km road trip :ROFLMAO:
I mainly just use the back area for gear storage etc
gwittman
I can't see it (302) being much worse on gas than that V6...
Just saying..... :sneaky:
I went on a long off-road trip with another Ranger that had converted to the Explorer 5.0 V-8 (same as 302). He was sucking up gas considerably more than I was. The Explorer 5.0 does not have much more horsepower than the 4.0 SOHC engine but the V-8 does look a lot better when it comes to torque. I think the 5.0 V-8 has more potential too if you want to build the engine for more power.
One thing to note is; he had problems with overheating when working the engine harder. He tried many things to resolve the problem but finally came to the conclusion that the engine compartment was not large enough to allow proper air flow for good cooling. It was a good install also. Looking at it, you would think it came from the factory with the V-8.
The new bumper looks good, That must have bumped up the weight. If you keep adding stuff you will need a V-8 to get it rolling. :)
UltraHDGames
Surprisingly this bumper on weighs 95 pounds so lighter then most but more then stock of course. I think next year when I get a front torsen lsd i might bump up to 4.56s but im not sure, the 4.10s still feel pretty good, think for now I'll start with a tune etc. Power still seems fairly fine with the 4.0 and it helps where I live is almost entirely flat
Hawk136439
Do you have or can you get some close up shots of you rack that wraps around the cap? I would like to build a similar one but don't know how to build the base plates on the bed rails and keep the cap mounting right since it overhangs the bed rails a little bit.
UltraHDGames
Not sure if this helps
Regcabguy
Oil eater.
You've done a super job. That's the nicest Ranger I've ever seen.
One thing though,the guys in the back must have hating life.
darrylkd
