arb098
Alright, I've got the dumb question of the day. I was driving the Gen3 this morning, and while I was sitting at the drive-thru, I noticed the temp gauge started creeping up. Kept an eye on it, and sure enough, it hit that dreaded H mark. I shut her off while we waited for our food (maybe 2 minutes), turned it back on, and pulled away. The second I started moving, the temp gauge dropped back to normal. It took maybe 10-15 seconds to fall back to the normal range. I didn't have the scanner hooked up to check the actual numbers, so I'm still unsure whether it was actually overheating or the gauge was going wonky. It's only done this once before and that was when I let it idle for about 10 minutes after a long day on the trails. Tried to figure it out then, but I couldn't find any issues.
I'm going to take a look at some of the common issues: possible leak behind waterpump, low coolant, fans, but I was curious if anyone else has had this issue before?
