Isuzu brakes...are yours like this?
Cuddy
Hi, hoping for some advice on the brakes on the nps. I know they aren’t the greatest and have read some older posts of problems other members have had, thankfully I don’t have the same issues as them.
As far as I know my brakes are supposed to be self adjusting -2013 NPS 300. When I depress the pedal it goes along way down. The brakes still work but don’t give me much confidence with the pedal so low. If I pump the pedal I get better pressure higher up on the pedal. There is plenty of linings left on the shoes. I’m wondering if the brakes are not self adjusting properly or perhaps I need to bleed them, if so, do I do this the usual way or do they need to be done with a vacuum?
Maybe this is normal? Does anyone else with a NPS experience this?
Cheers
trackadda
if on the first pump you have a low but hard pedal and the second pump a higher but still hard pedal the shoes need adjusting imo. i have not done mine yet [2007nps300] but normaly there is a star wheel type adjuster that needs to be adjusted manualy
Spanna 53
Yes Cuddy sounds like manual adjustment is required my NPS pedal is a bit lower after 28,000 kms will do a manual adjustment when I get home as far as I remember no of the Isuzus have self adjusters does make a big improvement did number one sons NPR his boys could not believe the difference after last service don't think they had been adjusted in 30 or 40 ,000 km . The only brake issues have been after water crossings drying them out quickly otherwise they pull rather badly a few application s over a couple of kms and they are fine again Ross
Cuddy
Hmm ... pretty sure they are supposed to self adjust. The adjuster is not like the older models, there is only a small hole where it adjusts. If you want to back them off to remove the drum you have to insert an Allen key or similar to push a spring/ wire back so you can back them off. If you wind them on too far and the adjuster is seized or tight it is a world of pain to deal with... so a mechanic tells me
javajoe79
Fabricator
Self adjusters can stick and not function. Probably worth removing a drum to have a look. They're basically the exact same as manual adjusters except a little arm rotates the star wheel if the shoes travel far enough.
Cuddy
Cheers javajoe, i was worried if I went to far I wouldn’t be able to back them off, will adjust them and see how it goes
zhukoveli
