Hi All,
After tallying up the parts, machine work required as well as sourcing another set of heads I decided to look for a donor motor.
I found a motor out of an 89 Raider SWB with 91k certified miles that ran. Brought it home and am starting the assessment. So far there doesn’t appear to have been any work done to it. There doesn’t appear to have been prior oil leaks. The cyl walls still have decent cross hatching.
So far my plans are:
- Front & rear main seals
- crank bolt update
- inspect oil pump for wear? (not sure on this one, might leave alone)
- new timing belt, water pump & water tube O-ring
- front and rear cam seals
- 3mm VLA’s
- valve stem seals?
- gaskets-oil pan, valve covers, exhaust,
- new rubber hoses
- get starter rebuilt
- misc tune-up items
Does anyone have additional suggestions on what to refresh while I’m in there?
