ExPo 70 Series Registry
Nicoyota
Here's mine (Showoff;))
Landcruiser 79DC 4.0L V6 (factory lockers F&R)
Model 2018
255/85R16 BFG mud
Old Man Emu
Alu cab
Rhino Rack
A work in progress
Here we were on our way to Croatia (sleeping in Slovenia)
WuJ_S6oHTMSBHq2rwqW3zSid3PF8MzkrrNLAAxR3jL7aEDLoT5vN5iRtQCWizI3jfdN19YaOyzD63rtjiyYFNfjOcRDBESBLY1XLQw2amjkITGhusP9K06G5sxXioPCOZYy5V77yDOIBL-ZrDR_2t7zk63f_cStvxR90mu_DkbI4IaV38lrbPzAg5TDrGkci53jdnCJoTZklC9hIzkOs93hHe-R-WxKu64leR418lDAEAyZ3YNvawTgZd5WcOvRDK4rK0zQl5NEKXNvtqPiJdnvUUD3R0Q0IzIVKQGt1T1ByJnqzmEjjIUx_-26MaZrANvm6A2yVEo87pHQ4OJlS_8sfj-USiAVfBTgiLLHPoD2z0_46q8FW1HTNF8Pczm1VuOJOBtV_VzmtBWPUkhUZmOOMSSNw1L8kVtJwgYnSNVjBN8Oy4krcHhwwBIqXW7nen4wztFhtRgJOwH57l-8CsBtdXP6VoFSk7UjFgCYO9EyEJ9QwaMyWNFSlPaS45kHfkG7Gt9apFl9mmOC0uQipdttgRxzHlobz_AvuUcg7ZYAh8LnMkt-Wp3dUBJcbdUeSXNWQgs99-p55AEssN4dPwxL0VJbZdCEU1C9BDTO6pY8gmCRDauvZ80bUsKzTshk=w1183-h887-no
Advmoto18
My 1988 BJ74...
Old Man Emu HD F/R kit
BF Goodrich on 4 corners/+ spare on Land Cruiser steel wheels
LCD winch bumper
Warn Zeon 10 24V winch (thanks to OK4WD for scoring this winch for me)
Factor 55 Flatlink E in OD Green with Ropeguard/Hawse Fairlead
Custom Splice 80' syn rope
Everything else stock from factory and Japan. And in great condition!
Many thanks to Steve @ Land Cruiser Direct!
Deshet
I just purchased a 1984 70 series.
Is parts availability an issue?
24 Volt Winch, Auto, removable top
I don't know much about it yet but it looks pretty good from the pictures.
4runnerteq
Ok, BJ74 is going to be my next truck. May be a couple or three years but Im having one. Where do I learn what to look for and stay away from and where to buy?
blowery
88 BJ74
Australian Market 12v,
13bt, 5 speed
ARB commercial bumper
ARB lockers front/rear
ARB compressor
OEM snorkel
dual batteries
OEM 16" wheels
Wheel flares
OEM rear rollbar, seats
Homemade rear bumper
Narva Lights
blowery
Ih8mud has a lot of info on these cruisers. Quick overview:
BJ74, Japan, Australia or Europe only. 1986 - 1990.
All right hand drive
FRP removable hard top or soft top. most were FRP. Windshield folds down on all of them.
MOST are 24v, Australia were 12v.
Engine 13BT turbo diesel 4 cylinder, 5 speed or auto
Some options:
Cable lockers
Suspension seats
A/C
Interior trims
Roll bar/rear belts
16" rims
Chrome package
PTO winch/bumpers
power window/locks
rear heat
What to look for:
RUST - 70 series are prone to fender rust but the fold down windshield is almost always rusted out. OEM replacement HARD to find, there are fiberglass replacements people use with good results.
The front end is the same as other 70 series in that time so you can use some of those parts.
You can pretty much find all the parts to rebuild the whole drivetrain easily on the BJ74. There are a few no longer available parts on the engine, but generally you could find used at that point.
The "BEST" BJ74 to find would be a 5 speed, cable locked, 12v loaded version...but that has proven to be REALLY hard to find.
Japan seems to be where most have been imported from. The Aussie spec ones usually stay there until they are beat into submission.
I also have heard good things about Land Cruisers Direct. There are a few for sale right now on ih8mud.
I would try and find the most SOLID frame and body BJ74 you can find. You can always swap a 1HZ or other toyota diesel into that drivetrain. Another option would be the BJ/HZJ/FZJ73.
The BJ73 was around the same time and longer. It comes with a 3B (non-turbo) diesel but the body is the same. An HZJ73 would be body-wise the same thing, just different motor. FZJ73, same body with a gasser engine.
I'm not sure how loaded the 73's came as opposed to the BJ74. Most BJ74's I've seen have been pretty loaded/up-spec'd especially from Japan.
bj70_guy
FWIW a factory windshield frame is currently not that hard to source. Who knows when they will go NLA, but for now at least, you can get one - I recently did.
Also of note is the new frames have breather holes all around the circumference of the frame. Hopefully this means the frames will now breath and not trap moisture inside and rust from the inside out.
Bonus, you can easily stick your Fluid Film straw in the holes and keep it coated.
One rusted out frame is enough :cry:
Advmoto18
If you are in the US, check in with Steve at Land Cruisers Direct. Steve is extremely knowledgeable and both honest and fair.
nas90tdi
Kris
1992 LJ78
JDM
180K KM
EX 4 door
Dobinsons Suspension 65MM, Air/Water intercooler,Fuel and boost adjusted, Large fan upgrade along with high flow tstat. Genuine snorkel. 1/2 rack, Larger exhaust next on list. Madman gauge+ separate boost gauge.
Replace my Land Rover 110 for a camping/traveling vehicle.
Deshet
Kris
1992 LJ78
JDM
180K KM
EX 4 door
Which do you like the best Classic Landcruiser or Classic Ranger Rover?
