2005 Tundra novice build - "The Rez"
Kpack
Should I be considering a carrier drop spacer at all because of the lift? I'm probably 2 inches over stock in the rear. Or does the Hendrix bearing hang lower than stock?
Also, wouldn't the polyurethane damper transfer more vibration to the chassis?
Cletus26
For the carrier bearing have a look at inland empire and hendrix motorsports. Both are much heavier duty. The inland Empire one uses the stock toyota bearing in a big polyurethane damper while the hendrix motorsports uses a sealed ball bearing in a machined aluminum housing that attaches to the mount with rubber isolators. I have been running the Inland empire bearing since I am 2wd (for now) which does not have a slip yoke on the driveshaft but the 4wd driveshaft does which allows me to swap to the hendrix motorsports bearing.
Sean
The Hendrix does work with the 4wd driveshaft on the Tundra?
smokeysevin
Re-redoing things the third time
The hendrix should work with the 4wd shaft, I can check tonight when I get home to be sure.
You will need to make a custom mount for either of them.
For the inland empire bearing I just cut the stock mount off and bolted directly to the cross member.
Sean
Cletus26
Sean
That would be awesome. A mount should be simple to make
Kpack
Project
Ammo Can Mounting
Purpose
1st gen DC Tundras are woefully short on storage space in the cab. I have no intentions of putting a topper on the bed, and no immediate plans for a rack. I prefer to keep the bed open because my truck gets used as a truck....carrying gravel, dirt, debris, wood, etc. I need an open bed for that, plus I prefer to sleep in the bed when camping. It was painfully obvious that there was not enough storage in the cab, so I looked at different options for adding storage in the bed. Recent threads brought to mind the usefulness of ammo cans.
Cost
~$50 (40 for ammo cans, 10 for hardware)
Time
30-45 minutes
Materials
2x 60mm ammo cans
1x 50 cal ammo can
10x 3/8 x 1 1/4 bolts
10x 3/8 Nylock nuts
20x 3/8 washers
20x 3/8 rubber washers
Procedure
I chose to mount the two 60mm cans on the driver's side of the bed, and the .50 cal on the passenger side (due to having the jack in the way).
Mocked up. The tops open opposite each other.
y4mm5ff5kAwXnqIolhlXBcjlwwWnESJsRtJ5doSD4xVo2UzSqAfUmczGlYi8JvQLmVJWCkqg8ipxszlC2Nresz28d-XnQbgzebzr41gLpOTumuurfm9QjGwK07_zfvJRo4kc9IpqlX-8ITTRmsLTnssZ6OP8FXX4B0uk4LPiW0sAcWeBG5Fm5qPTyP8mkF424xe0S9FW7dyMmcD4nqJo5v0ZA
y4mYe1QD-cgZr0Alhv2mlopcbB45Op_KUYEqsrbu9jNr3OX10ehvr1edpKgJjdv3dd8_qF6pooFh_VvQm-KoU6VM5pyNOqpHghXNYxEPELdtZrSyIHqGhb1haSb5VOB2G5UBmpU8OAiWHeARIIFTV2MAqOGTjuW3pQyzI5mb2W-xLNg5T1EJqfRFzDknh4ePMcLxvdRmiwL7LL-y5SI5dgjuA
They don't stick past the wheel well bump, and are under the lip of the bed by several inches
y4m7b1ZBnsnOLkL5kXjU0Xw6A4UmID6VzdjMwOFJ_nW8G7iaWvnMXh3GP9cV871TKWDiiTPhhorR4EARIZkWWQDCWWsa018v4nOSk4UClLboQHx3-yT6maTjJ5e-0riAlrdaBYiSQ4KjLF2u26kyAlKs0hckfKszxepygy8v_PuUgvlR7IXdT4HWqmf6qN-LKeTK6gm0LymejpL_hPvP8dXFw
Mark hole locations on the bottom of the can:
y4m3djBT_m9e2woaG-1U4IgEAT2UWceSc_DDtaj2Mp5E_pLtzo1f184HY759ML162TRQFZw_HsQxIkqbNWtLiCUkirO5Rjq1Y35z27_Ovs9nNofivi37U7K3k4lEIxtWeMbUud1EJ6EQuu2TIzzGSmvGyOUCzH6nPYbqgclP0mCwFFXD03R-FzTv4yF5zWMNVTlqQPlpXVEmlSMr-DWqWvzjw
Drill out with 3/8 bit:
y4mIFng-q0HHlLQvIh8jgNc_zOfw-3BbkPJcIxqw95RXStb7n0vsISdFiN4H1r3oClLtWgA0S_GBX07iuulXjfLMUnmHgwjMQIL5W4T46B8Gaxv7tN8Fqv-WkbAXoTJL5JaTmWUW7zPmKw_E2jPRCuVpkdVs8UE0N7YPgW5bKD-Hx88AzL-tuQIZ8AP_bH0Iq3wqP-BUfZjN7RND9F5vTjmwQ
Put the can in place on the bed and mark the location of the holes:
y4mKgSwMG2b3zBBn9NeORrPvRWjz_1RYJRJiZK18lj7OPxOGmB4ElOf4_uoHuxaVz_t7pIoBCGKOT_oHpvc6Q0FISRg7v3vC5gQTjzGuuEtcSUR-tX6ieRzqcKea1r4RDXYCQiQbkA79TueuYERr74GT0YyGXggDYYcsnCTDIpOfpDI7qBwewJJOAYIu6ZKXbEMtnY1jACNMCya7wIKU4BtXA
Holes drilled:
y4mtPuRlD23pn-_VLdSKfQaXSbavGj3Z_oQAFTZQOkJGf5hcoY2Uq3ThIoVl_ZoKSEzX1scH52Cb8iAo66RmXyDtoDGJhIr5IqzTVgVUSS58aH9sfTPCrSxAsbQ1qx1AHG_cHHjYbKfhTiTgSYHP8M0_iJnsxl4g8QOXjNz9ILYCOjsgnXy4-aN1RFLOUrbF2cAo3rh8ujPogHetJWjYJ9zjA
Assembled like this. After the first can I changed it so there was a rubber washer between the can and the bed, so it went like this: Bolt->washer->can->rubber washer->truck bed->rubber washer->washer->nylock nut.
y4mQ937gpcA36FGkJ2omteN6-7K2W1vQnHDevTwigi_FWB-I92cuuzrApZtKaBwj6ZB6bW2XnVjn6tbJwji_6OxD2NVUgtTdSf6apn-mE-Apv1weHC6J23DF8ItNzGitieD9jEySBaT5mrwgEqu_o0L5SnRHLUTpI7apLoDChphYABiD8N9g-PNIdq0ULxyRIzytyEnxbgM3sPwy4xNysPHuw
Mounted underneath:
y4mgW5jXjMZtPl6TfnRmJc-JbdKNwjgM0zSzlFxqNRQqngFUbKWQxyD70V5M0joLkEEAeLj69cpblk1cWF8GAZqo_3SyljwMEr-rNRtX9JijSIe9x9ue5ItH_Do2G83iN2JbmWkpoIFP8YZ3yAlZ7q5GPkVstEStgm6pvhJxLbsv-r58w0s2SO9CHIVhTjTTVMFgGLZg0PoTz0aW6GfmTjcCg
From the top:
y4mB_Hqpu-tqfTAKF4dF3xI5C-7vP0lsOzHxwa5NFra0BAQ1EVwNdmSZKhWFCnpVSGH_IrP1hyMCtaJedDOZK3cULwrihbNpZV89j3WstgUTS_BUy1OjG2gy4BvTawkoxhj33bHkTjKkxh5_HZrxJo3WpLTZoL6zrDXxnD_5KHxURCmc01nQQ72lAuYJZH9FK2M2PdRSaRy3UsK55fS8kv_TA
Rinse and repeat for the other 60mm can. Here's a shot underneath showing that all the bolts are clear of other structures
y4mXFsR_0JuiEiZwKb-39iF8TVnpOHILdD7CokSqoskoIEdZ6EJ2spDpDIqhlAUyhHBuf9-YIfPEINSRgY_27iivobzD0AaUKh16XhdC7AnvasJenY9O4tnba5LXGzCoIE8YOFy3aMh8sZO65Ao1NHzQROkNKWP-fQeyi7SeK4nRJlRAP2DW9tB9LBlhQWQqWJHe1szO3mie-LxuNt7DJutEA
Inside of can #2 showing that the one bolt needs to be moved towards the center due to the ridge on the bed being shorter (close to the wheel well)
y4mfZtG68USLP222JSHnlOXnAtKxbnR1btm0xjIMqNl-d7jxLmxA0HMbQginOlIZSLjqY1Xz6JzT1STjC9aA3-HuCufZISb5gM4LvHleU8YcR7tKV3eaAcJn_t4U6patCOW7Lg2VHY3ELWDGi0jAGFR9uezhH57BkpOzyR-Nrkui7FLJ_EsMR3bsjjQxOtaVfXicP07oSf2cNGQGX06vazDvA
All done. The .50 cal can on the other side is the same process, but I only used two bolts for that because it is so short.
y4mjVQWLQieNVc-Ek9-nJU46cXldXnYh9LM9SIN5PPGWNXuvAgtFXt9m2VhiHv_X1lbQt621vjw08x-jJwFMjpshuJlp89wig35x86mwZg1ChoXA4BXf72J1x6qTfbjZCRfqob4hGhcBLgEDKmbuNwMtRgi_0F6fHYjyYJMwUi1XiIynQdfZalKbg9k8lXAA20AQzEM9FLurCGymAzaHFb5rw
These cans are solid. There is zero movement once they are bolted down. The seals are all in good condition and only minor surface scuffing/rust on the outside. Eventually I may paint them.
The rearmost can holds all my straps and recovery equipment....tree saver, tow strap, 4 ratchet straps, and cargo net. Eventually it will also contain other items like a snatch block, kinetic rope, etc. Plenty of room for all.
The other 60mm can holds all the fluids for the truck. 1 bottle engine oil, 1 bottle ATF, 1 bottle PS fluid, 1 bottle gear oil, and a full thing of red coolant. The .50 cal can holds nothing yet.
The set up now as it currently looks. The spare tire is temporary until I get a rear bumper made by Brute Force. The Scepter water can I bought from the same guy for $30. I'm going to pick up one or two more.....I'll mount two on the bumper when I get it.
y4m6yJuNxi2dZUE9MrhE9aVMCyWyO_HVr0GsPQOf9QcJIQgZEBlXY8Iqp6MBi6twwUUn1kD_VPC4C3TDtTSTv6xivJMNN37akjDYHqoXNRAbU3a9ex289x9MTX1nqvB_nxF96GZgt75M_ImxdGLT2Bjg_1gG3IhqQYz8xeIWYEMrkt2NAfaiIxQyvozkIqz3twPfM_hVTC1CKOu_5j5ifzRGA
jswift716
Project
Ammo Can Mounting
Purpose
Cost
Time
30-45 minutes
Materials
2x 60mm ammo cans
1x 50 cal ammo can
10x 3/8 Nylock nuts
20x 3/8 washers
Procedure
Holes drilled:
Mounted underneath:
From the top:
Did you paint or seal the raw metal anyway? If not that's gonna be your first source of rust and Rot on both the bed and the cans..
Sent from my SM-G965U using Tapatalk
Kpack
That's what the rubber washers are for. They squeezed out nice and evenly on all bolts so they should be well-sealed. I may be totally wrong on this, but I would think the rubber washers would seal out water and moisture very well.
When they build pole barns around here they drill right through the painted metal sheathing with a screw and rubber washer. The rubber washer is the only thing that keeps moisture from rusting the metal and rotting the wood underneath. If it's good enough for that application, wouldn't the same be true here?
jswift716
Sort of, most metal roofing I've worked with was also painted over galvanized sheets. Plus a little extra rattle can paint is cheap insurance, I usually paint and rtv anything like that but I'm in ny and have salt everywhere 5 months a year
smokeysevin
Looks good, I have 2 40mm cans on my tire rack, the only down side is that the 40mm cans are not hinged, the lids come totally off so you need to secure one side if you want to be able to lock them. I wish the access cab bed was deep enough for the 60mm cans.
Sean
Kpack
Good point, and yes painting is cheap insurance. We don't have it as bad here in WA as you do in New York, but it's not ideal either. They're easy to remove, so I may end up pulling them off, applying a bit of paint, then putting them back on.
Sean
I had forgotten about the depth difference between DC and AC Tundra's. The 60mm cans are nice....lids are hinged, and the amount of storage inside is awesome. As far as putting locks on these, I'm not sure if I will or not. On one hand it would be nice to have them secure, but on the other hand I don't like the idea of listening to locks bouncing all over the place on the trails. Plus if anyone decided to open them they would find there is nothing in there of great value.
Kpack
I'm east side of the mountains, between Yakima and Cle Elum. It's not too far of a drive for you....we ought to meet up and hit some trails. There are three major trail systems around me: Liberty, Naches, and Manastash. I haven't done the first two, but have explored a few of the trails in Manastash, and they are tons of fun.
There are a few other 1st gen Tundra guys here in Washington. I'm all for getting together for a 1G Tundra trail run.
Kpack
Trip Report
Buck Meadows Jeep Trail, Manastash WA
My friend and I hit up a local Jeep trail today for a morning run. We did the same trail last year, but it's still fun. It's a little over 6 miles in length and varies between open areas and many extremely tight spots. It's a tight fit in some areas for even a smaller Jeep, so my truck is a bit of a challenge. To be honest, I'm not sure how I did this trail last year without sliders. They are an absolute must if you're running anything longer than a Jeep. Also having a spotter is necessary with a larger vehicle.
About 1/3rd through the trail you encounter this fairly steep drop-off and tight corner. Having done this last year I was more confident and smoother this time:
The last 1/3rd of the trail is in thick trees and very tight. There was a fun rock obstacle that I'm glad I had sliders for.
This last video unfortunately didn't record one of the slicker, steep, and tighter sections. The screen capture at the beginning shows the view from the top of the hill, but after that there was no video. The second two shots are sections after the first that are somewhat steep and tight, though not as interesting as the non-recorded section. The popping you hear is from a Samurai that was also part of our group.
Lessons learned:
-Sliders are a must. Cheap insurance and also super helpful with a long-wheelbase vehicle like mine. They were great at pivoting me around some very tight tree trunks.
-Popping noise coming from the front suspension. I will need to go through and evaluate/re-torque everything.
-Rear suspension is terrible.
-Overall suspension needs improvement. Good enough articulation for what I need, but absolutely terrible on washboard. Like really, really bad. Even with tires down to 15 psi the washboard was almost undriveable. I need ideas on how to fix this!! I have to drive at least a dozen miles on washboard before I get to any trails!
idriveabox
Following this. Also drive a DC and looking to redo the rear. At least you have sliders! Looks like they saved you on those sections.
Is your front sway bar installed? Could be source of popping. I threw some new end links on and mine is making noise on the trails already.
V45W_Proto2.5
