Jeep XJ Pop Top Camper Build
CraftsmanCollaborative
Touching on the other areas of my build, here is my one ton steering setup on the cherokee:
Cavfab OTA trackbar and alpha Steering Kit, also with the cavfab short arms installed.
Beefy, killed the majority of my death wobble, and they have a “no bs” warranty they already honored for a failed builder part.
Since that picture I changed the draglink to run under the pitman arm, which eliminated any bumpsteer.
Found some more builds that give a good insight into the poptop process.
First of all, some of the suburban guys adapting their own diy system here.
^Interesting take on a full DIY top from the fiberglass to the hinge system.
Especially the Cantilever system with the electric actuated component.
Also, found an extremely detailed build of both a fiberglass pop top mold and the finished shell on a 3500 EB Chevy van Here.
Really clean top, and better than even some production runs I've seen.
Opens up the possibility to recreate the top many times and custom fit the vehicle.
msimmo
2nd link is the same as the first, I would love to see the E350 top. Awesome build, getting inspiration for my comanche.
Pulled the top again today and started on the edge profile for the roof chop. See the difference from the original temporary cut and fold I did below. Down below will be a fullsize sleeping platform so having the entirety of the roof cut will give the roomiest Jeep camp setup possible.
Many have asked why I don't build a loft up top instead to function like a rooftop tent setup. For this build, I wanted the ability to sleep in the lower cab of the Jeep when needing to stealth camp or when the weather is particularly rough and windy.
I used some 1”x1” angle steel, once I get more material I’ll wrap the whole roof edge of the cherokee like this, and devising a system to mount the hinges straight to it and be able to remove them easily to run topless.
The flat bar sits pretty well among the back 3/4 and lines up over the factory roof rack mounting points. I cut off the rack nutserts and spot welded it all in place for now. The front 1/4 needs bent with clamps to fit the curve up to the windshield.
Looks way better in person compared to the old fold method.
As I'm progressing on renovating the camper concept, I've done a bit of clean up
I've removed most all the rattles by fixing the dash and removing loose interior plastic panels, but the lift gate bounces like crazy.
Anyone have any experience adding an additional seal, latch, or otherwise idea to eliminate this? Drives me crazy heading up the trail to camp.
I will pick up some new screw in "bumpstops" to see how much of a difference that makes, but as of now is the only part of the body constantly bouncing/moving.
Also threw code P0740 (torque converter clutch circuit) again today, throws it occasionally and seems only when doing a lot of errands around town, stop and go and once heated up.
AW4 Trans runs fine, fluid levels proper, any idea on heat affecting solenoids or wiring as a possibility? Insight appreciated.
Picking up more material from the metal supply tomorrow and then will finish the passenger hinge and rear push-bar brackets.
Are you planning on making a sleeping platform up top or just using the pop up for standing room?
Still unsure on this. The lower will definitely have a full-time full-size bed. This holds the advantage of more head room with the top up, and the ability to still stealth camp comfortably with the top down.
I have a hammock/cot concept or to do something like the GFC Tacoma platform, but really don’t see a point except for hot nights or sleeping extra visitors/friends?
Sleeping on the lower with the top up feels overly roomy.
Stopped in the metal supply this morning and got the remaining material for the roof edge lip. The cherokee took two 10’ angle steel to run the perimeter.
Lining it up wasn’t too bad, just took time and patience with the clamps. Forgot how much I dislike flux core welds though... exchanged my empty 75/25 mig cylinder for straight argon to use with the spool gun and in the meantime have flux for everything steel.
The rear was the hardest section to fit. The front surprisingly went ok, but bending the angle to the curve of the rear took a good minute. Didn’t help that where I needed my clamp to sit was along the rear joint of my cage. Figured it out eventually and had to run the full inch weld right away as the spots would snap by the time the clamps started slipping. Now is fitted nice along the curve.
Test fit everything once again, then run stitch welds into the body and go around with seam sealer to fill the remaining gap.
If I were working on someone else’s rig I think I’d just go ahead and rivet the edge frame into place like a lot of van conversion shops do along with rtv. Think it would be better than worrying about welding thicker metal to the roof.
jeepdreamer
Another option for more interior space is to reshape the floor. I ran a t-case drop on mine so the tranny hump rear of the front seats and the back seat "well" area all got removed. Enough area is created to add a good size water tank or ???
Just an idea I thought I'd pass along.
Stop!! Don’t tempt me to chop my body more until I can finish the current project
Nice work though, I was thinking about relocating the ebrake adjustment bracket along the drive side of the Floorpan and putting a 4 gallon rectangle water tank under there with a belly pan to keep the interior open.
Just crawled under the jeep and actually seriously considering this now.
How hard was it beyond taking the time to bend the new floorpan and fit it all in place?
Any issues with driveshaft clearance when the rear suspension is fully compressed?
My bed platform will sit over this regardless, but that’s a good bit of storage for this size camper
jeepdreamer
It was actually a lot easier than you'd think. Relocating the charcoal cannisters was a small pain but driveshaft never came near anything.
zhukoveli
