Need photo: Fleetwood Neon Crankshaft
pokealong
Hello,
Fleetwood Neon...The drive hub extension connector fell off when I was on the road.
Could somebody take a picture from underneath their trailer so I can see what it should look like? I can't find parts anywhere so I'm going to have to manufacture my own..I did find the schematic and part numbers, but apparently there are none to be purchased.
Below is the photo from under my trailer.
-iLd62yDzbbDawWivp8Hv-SUfvWRBE5zBuATxFoybn7ki4MbFWIUp0JAxEEmpiNiqRm81BmZHe0sdFJBEK4raWXIPLZwiBdNNSLpfH4mLU_y3JhlrBGWlrbMP2Hgflszk8oH5rw9
Here's what it looks like where the crank goes in.
DBp9bCKk6cdy7eC9oYTWoqLB0WF7SMFg4ZfsIK7aY-0vwgADprHxPdD4Uv30gqP0PanBZkweKquhsY4VxYueo6TED8xnhe2epQMq8HbjyjzivCTqCzGTZJ7JARPREHeHdC3aMfEv
You can see that there is nothing to put the crank into. I think that the extension is really just a guide for the crank, so I'm pretty sure it won't be hard. But I would like to know what it should look like underneath there.
thanks in advance for your help. My trailer is a 2007, but I don't know that that would make any difference.
Steven.gresham
Hi Steve,
It looks like you are also missing the drive hub extension. How are you cranking it up?
And yes, I have talked to all of the usual suspects!
Lynn
There’s a linch pin that is in the place of the extension. It requires a longer crank handle but works fine.
Goldenbora
