MartinDWhite
I would think the soft shackle or rope used to attach the ring to your anchor would get very warm do to the friction. Would that heat weaken and cause excessive wear on that soft shackle or rope? Wouldn't the knot in the soft shackle or rope also be a weak point?
The soft shackle knot is not seeing any more or different force than it sees during a recovery without a pulley. The knots in soft shackles are no more of a concern for this application, than any use of a soft shackle for a recovery.
Heat is generated by force and speed. The pulley rotates very slowly on the soft shackle and that heat is absorbed by the mass of the aluminum pulley well before it would be enough to hurt the rope. A little googling shows that most winch line is of a fiber capable of short bursts of temperatures of 130*C (260*F) and sustained heat of 70*C (160*F) (https://issuu.com/eurofibers/docs/name8f0d44). This means the aluminum pulley, which is a great heat sink, would need to be hot enough to instantly boil water for it to do damage to the soft shackle or hot enough that you can't touch it if the pull was longer than a few minutes AFTER the pulley got hot. Both of these are not possible without a dramatic level of abuse of the equipment that I don't think can be reached with any winch on a vehicle.
