Trailer wiring solution / help
blackohio
My taillights have RED / AMBER / REVERSE
Im assuming it's intended to run like this RED (RUNNING BRAKE ) / AMBER (TURN) / CLEAR (REVERSE)
However the trailer harness has it setup like this running / turn / brake for right & left all on the same pole inside the junction box.
Will there be any issues not using the amber as far as registering it as a utility trailer? Or should I tap the amber into the harness for the other sidemarker lights?
Additionally I dont see anywhere for the reverse lights on the trailer harness.
ottsville
Flat four plugs have no reverse wire. You'll need to go up(bets bet would be more common 7 prong rv connector). Depending on the state, having a light that doesn't function, your clear, might be illegal. I wpupd mount a cheap trailer light for inspection/titling then put your desired lights on.
blackohio
my truck has the oem tow package which has the 7 pin round plug. i’ll look into new lights rather than cobble this along
ottsville
If you have the 7 pin round then there is a reverse light wire on the truck iirc. You just need a different plug on your trailer.
ITTOG
Only 7 pin connectors have a reverse light wire. However, most trailers do not have a reverse light on them. I have two trailers with 7 pin connectors and neither one is using the reverse wire. A friend has a 5th wheel and it doesn't have a reverse light.
Jmanscotch
is wandering
Yeah, trailer wiring and such.
Is that a VW Corrado I spot?! I’ll trade pics of car for wiring tips!
ETrailer has good options for 7 pin connectors and wiring. You can buy the connector, x feet of 7 pin wiring and a 7 wire junction box, then some 20-30’ of 4-pin wiring. Then wire the trailer from the box back with the 4-wires. Easy to add and modify trailer wiring this way. It’s what I’ve done on my last two builds, it handles marker lights, reverse lights and all really well.
Jake
blackohio
Jake
it is a corrado. i just sold it saturday. decided i wanted a new husqvarna fe 500 and i did not paint the steering column surround PO did.
2CA142FC-D106-4A2A-83E5-B001CC1B85A0.jpeg48A0EFC8-7446-4C42-AAC3-D9ED70F12E49.jpegC8486A5C-5444-4EB9-BB4D-FB570E2D9961.jpeg1D4D4FB7-8817-4EB2-B679-603E85C6D886.jpegA4AC4CEE-D3C5-4651-8B0D-03DD00C75040.jpeg13149BC8-A603-49A2-B78A-6866133F5943.jpeg1F725220-0203-481C-BA3D-8785DDA50B7F.jpeg85A24CB5-A8A8-4150-868E-B8EBF1FE6B9A.jpeg8BD90541-1256-4BD3-9916-580C67FE4653.jpeg
blackohio
pretty excited got hooked up today with RiskRacing and will be running their lock-n-lock PRO moto mounts and Striker scene lights.lock_n_load_pro_bike_homepage-5_2048x.progressive.jpg
oskarf150
