$200 5KW Portable Diesel Air Heater
Kirby McRae
I did some searching and came up empty. Does anyone know if there are versions of these cheap knock offs that use gasoline? Id rather not have to carry an extra type of fuel besides gasoline
I was participating in a discussion about running these units on gasoline (also the espar D2). Best we can tell there is not a whole of of difference between the gas and diesel versions. The combustion chamber is slightly different, and the initial fuel pump ramp speed during startup is different. Diesel and gas have similar enough energy content, that it should run successfully on gasoline. For 200$ it may be worth a try. Just test it thoroughly.
With espar/eberspacher, the D2 (diesel) and B2(gasoline) (B5 and D5 as well) use the same glow plug, same fuel pump, same blower motor etc. Only the ECU programming, and the combustion chamber are different. The Diesel versions have a mesh screen to hold the flame in place, while the gasoline versions use a couple of smaller tubes and flame holder fins.
I have heard yes, but not yet found any.
If eBay doesn't show them, ask the sellers.
I'm also looking for hydronic / block heater style rather than forced air only.
Authentic Espars are available in both diesel D4 and gas B4 versions. They use the same blower motor, case, gasket, fuel pump, heat exchanger, and glow pin. BUT, they are not the same. The differences are in the burner tube and in the control unit. The diesel uses a slinger system of 2 spinning disks spraying the fuel out between them. The motor shaft is hollow and fuel runs through the shaft to an space between the disks. The gas version uses a fixed jet. They also use different startup procedures and air/fuel ratios. This might seem like a small difference, but it's not. And when playing with volatile fuels like gas you're asking for trouble if you run them in systems designed for diesel.
This is what the diesel burner tube will look like: https://esparparts.com/252113100100-p-25147.html
And this is what the gas burner tube looks like: https://esparparts.com/combustion-burner-p-25157.html
It's not worth trying to run a diesel one on gas. It's dangerous and likely to not work at all. As far as cheap ($100-200) gas versions, I have seen them advertised but you'd have to actually take one apart to tell if it is a misadvertised diesel model or an actual gas version. But for a bit more these guys have them and they are pretty reputable and have good reviews. I'd recommend just running a diesel version off of a 5L-10L tank though, diesel is a much safer fuel and 10L should last a long time.
Those guys also have the block heater style heaters available. Don't know anything about them though.
luthj
Engineer In Residence
I have had a D2 apart, and there is no hollow shaft or spinning disk in the burner/chamber. The glow plug and vaporizer screen are the same between the D2 and b2.
john61ct
Very useful stuff. Completely agree crazy to think try to convert designed for diesel units to use gasoline fuel.
Website does not inspire, UK "presence" is likely just a Brass Plate at a company registration lawyer.
But interesting if cheap enough!
Here's a cleaned up dump of the main page:
___________
Drivworld Group Industry
Parking Heater
Heating the passenger compartments and cabs of all kinds of vehicles, without having to depend on the heat given off by a running engine.
Chicken wire, welded and woven mesh specifications in Galvanized Before Weaving/Weld (GBW), Galvanized After Weaving/Weld (GAW), PVC Coated and Stainless Steel. Various Garden Mesh, Aviary netting and mesh, Dog Fence.
High Pressure Pump
Cleaning any dirt
Cleaning machine rental civil, industrial, municipal, power, chemical, oil and other industries of high pressure water cleaning construction services, dry ice cleaning services.
Stainless Steel
Material to improve quality
Stainless steel coil,Galvalume&Alu-Zinc Steel Coils,Colour Corrugated Sheets,Deep drawing PPGI coil,Pre-painted Galvanized Steel Sheets.
About us
Drivworld parking heater is a brand of the Drivworld Group which locates in London and has a registered capital of 8 millon pounds. With the Britain's tech and taking the chance of China's grooming manufacture industry, the Group makes its investments and builds its factories in China, with a result of providing the convenient and excellent market servive as well as the low consuming cost for customers. At present, the company mainly sells parking heaters and is developing a series of products like car-carrying refrigerator. and defroster.
The Group is now involving four fundamental industries, this is, parking heater and accessories, high pressure piston pump, stainless steel metal materials and metal mesh, all of which rank in the forefront of their peers in the aspect of tech. The company can offer low cost and excellect service to its customers with the quality guaranteed and cost lowered by its holding plants bulit in China. And the company is expanding the market right now, so we hope to set business cooperation with some more powerful companies.
Advanced car independent heating program
In the cold winter or alpine region, maybe you want to be able to go out into the warm car room, but the vehicles often need to warm up, then, a set of independent of the engine heating system to make driving very comfortable!
Technology
VVKB 5KW Parking Heater Diesel Heater 12V Apollo-V2 CE RoHS FCC Certify
Affordable BTKJ series - 5kw 12V/24V diesel air parking heater with Rotary switch
High configuration HRLF series -5kw 12V/24V diesel air parking heater with Rotary switch
Drivworld parking heater - Stepless power regulation from 1KW to 5KW 12V/24V diesel/gasoline air parking heater with LCD Rotary switch
Affordable BTWT series - 4kw 12V/24V diesel air parking heater with Rotary switch
Affordable BTKJ series - 4kw 12V/24V diesel air parking heater with Rotary switch
Affordable series - 2.2kw 12v/24v diesel air parking heater with Rotary switch
Affordable 2kw air parking heater with Rotary controller-similar to Eberspacher heater
BTWT series-Vehicle Heaters and Marine Heaters
2kw air parking heater with Rotary controller-same to webasto heater
YZHY series Vehicle Heaters and Marine Heaters
5kw 12V gasoline air parking heater with Digital control--FJH-5/1Q
5kw 12V gasoline air parking heater with Rotary controller--FJH-5/1Q
5kw 24V diesel air parking heater with Rotary controller--FJH-5/2C
5kw 24V diesel air parking heater with Digital control--FJH-5/2C
5kw 12V diesel air parking heater with Rotary controller--FJH-5/1C
5kw 12V diesel air parking heater with Digital control--FJH-5/1C
4kw 24V diesel air parking heater with Rotary controller--FJH-4/2C
4kw 12V diesel air parking heater with Rotary controller--FJH-4/1C
4kw 24V diesel air parking heater with Digital control--FJH-4/2C
4kw 12V diesel air parking heater with Digital control--FJH-4/1C
High quality BL series 2.2kw 24V diesel air parking heater with Rotary controller--FJH-2.2/2C
High quality BL series 2.2kw 24V diesel air parking heater with Digital control--FJH-2.2/2C
High quality BL series 2.2kw 12V diesel air parking heater with Rotary controller--FJH-2.2/1C
High quality BL series 2.2kw 12V diesel air parking heater with Digital control--FJH-2.2/1C
2kw 12V Gasoline air parking heater with Rotary controller--FJH-2/1Q
2kw 12V gasoline air parking heater with Digital control--FJH-2/1Q
2kw 24V diesel air parking heater with Rotary controller--FJH-2/2C
2kw 24V diesel air parking heater with Digital control--FJH-2/2C
2kw 12V diesel air parking heater with Rotary controller--FJH-2/1C
2kw 12V diesel air parking heater with Digital control--FJH-2/1C
4kw 12V/24V diesel /gasoline air parking heater with Digital control
Rotary controller for parking heater
LCD switch with remote control
The Remote controller (30 meters)
Affordable series -5kw 12V/24V diesel /gasoline water parking heater-battery operated heater
9kw 24V diesel water parking heater with Digital control--YJH-Q9/2C-S
9kw 12V/24V diesel /gasoline water parking heater with Digital control--YJH-Q9/1C-S
5kw 12V gasoline water parking heater with Digital control--YJH-Q5/1Q-S
5kw 24V diesel water parking heater with Digital control--YJH-Q5/2C-S
5kw 12V diesel water parking heater with Digital control--YJH-Q5/1C-S
5kw 12V/24V diesel /gasoline water parking heater with Digital control
Remote control for parking heater (800 meters)
GSM mobile phone controller for parking heater
Digital control for water parking heater
Digital control for air parking heater
Kirby McRae
My bad, I have never had mine that far apart and got my info from this guy - got lesson of not trusting the internet in for the day. And now that I've been looking at the burners I agree with you. I don't have a gas one to look at and can't find very good pictures either, but maybe he got them confused and the gas models have spinning disks? I'm not sure where the motor would be though. Maybe the old models used spinning disks? Anyway, thanks for the correction. I wish I knew what he was talking about though.
Kirby McRae
Also, even if the diesel combustion chamber would work fine with gas there is still the problem with the controller. I've attached a PDF somebody else put together of how the electronics in the heaters work, most of it is above my level of electronics but he lays out how the controllers work really well.
  • V7 - Hacking the Chinese Diesel Heater Communications Protocol.pdf
hour
I like what you've done there. Any issues with the unit getting hot in the box? I want to do something similar, and hang it off my spare tire. Then run the fuel line into one of the jerry cans on my swing arm. I would extend the vent up into the rear door of my RTT.
Cool this thread is still going. Yeah it does get warm in the box as the entire unit gets warm. I could also do some better sealing of the hot air out side to the flange i put on the box. In hindsight, if installing a unit like this in a tool box, don't mount it centered in the box. Push the unit over so the hot air outlet is as close as possible to the side of the tool box. Better to ensure all the hot air is going out and not accumulating inside.
Can't wait to get one of these LCD controllers to run instead of the janky included one that I still don't really understand. I only got maybe 12 hours of this running this year, between 5k-8k feet. It worked well, and I'll like it even more with a better controller.
Since I have no use for diesel in vehicles, and ended up with extra diesel in my garage, I think I'll treat it to convenient bottle of kerosene from the hardware store while I figure out what the heck to do with nasty old fuel.
luthj
Diesel tends to age slower than gasoline. The major aging mechanism for gasoline is evaporation of the volatiles, leaving behind a stew of heavier materials, semi-organic gums etc. With diesel the aging mechanism is oxidation. This can cause long chain waxes to polymerize, forming plastic like coatings when disturbed and pumped. These polymers don't vaporize well, and can cause coking in some instances.
If water gets introduced, microbial growth at the water/fuel interface can rapidly create a stew of organics, oxidized metals, and nasty business.
snowfiend
I think a 2kw would be great for our small wall tent, much easier than lugging the wood stove or 20lb propane tank heater. If you were to put a battery in the box to be self-sufficientwhat size would be suggested to balance portability and runtime?
Seems they draw ~9 amps for a few minutes at startup, then drops to .5a at idle. If it ran overnight for 8 hrs let's call it 5a used, so a 15AH 12v deep cycle AGM battery might get me 3 nights before needing a recharge? Something like this: https://www.mightymaxbattery.com/p3421824/ml15-12-12v-15ah-sla-battery.html
Utah KJ
Free State of Florida
A proper overland rig should burn diesel anyway. :p
My heater should arrive this Friday, and I'll be putting something together very similar to the OP. I think that I'm going to drop the fuel line into the jerry can already on the bumper rather than use the supplied tank. I may use that if I ever get my 4Runner campaign-ready.
