Install & Review; Falcon Sport Tow/Haul Shocks on a Ford F150
Greg@RME
About a year ago I was able to visit Teraflex in West Jordan, UT and spend a few hours with a couple of their Engineers going into detail about the coming line of Falcon Shocks for trucks. (As of now, not only does the Falcon shock line cover Jeeps, they also offer shocks for the Ford F150, Chevy Silverado 1500, Dodge Ram 1500, Toyota 4Runner and Tacoma. I have heard that other trucks are in the works.) After walking thru the Falcon shock production line, seeing the shim stacks and valve tuning, hearing about how the negative spring stops harsh bottoming out on full extension, the shock bump stop gets rid of harsh bottoming out under full compression and the entire line of very high quality parts that go into building the Falcons, I was impressed.
The next thing we did was take the Falcon shocks Ford F150 Ecoboost truck for a drive.... on the road it's very stable, even predictable when you throw it into a HARD turn. They found a big, empty dirt lot that was ROUGH and proceed to push this this Ford F150 HARD offroad.... and it was incredibly impressive. The truck was stock other than Falcon shocks, Raceline wheels & BFGoodrich KO2 tires. The Falcon shock engineers were hitting rough ruts, pot holes, mud puddles, etc at speeds up 65 MPH and the truck was handling it all with stride, it was totally controlled and planted, resisting hard bottoming out.
The engineers mentioned that during R & D testing, they've broken wheels, blown out tires and the suspension components are surviving without issue. The ride on the road was impressive, offroad was amazing... considering it was a otherwise 'stock' F150, the truck was capable of incredible speeds over ROUGH terrain.
After running Falcon 3.4's on my Jeep, I've been a huge fan of these shocks. They changed my Jeep for the better, on road and off. When we bought a Ford F150 for my wife's DD and my weekend tow rig, I decided we wanted a more stable towing experience, better off-road performance and a better all around ride, the choice was an easy one. We choose the Sport Tow/Haul Leveling system for our needs. I wanted to upsize the tires to 285's and make the truck not look so stock, so we set up the shocks to level the front end. The Tow/Haul shocks have a 3 stage setting, Comfort & Control, Moderate Tow/Haul, and Heavy Tow/Haul settings. Far as technical specs, the Falcons are built as follows;
• 2.25” shock body provides optimal performance
• 6061-T6 aluminum alloy shock body resists wear & protects internal components while providing superior heat dissipation
• Smooth honed internal shock body surface for long-term performance
• Largest shock body that will fit w/out modifications
• 3/4” induction hardened chrome plated shaft resists rock damage & corrosion as well as prevents shaft buckling
• Maximum shaft diameter allows for more precise tuning
• Hard anodized billet piston
Here's photos of the Falcons, the build quality and finish is very high-end! Each box of Falcons comes with a card signed by the guys that built your shocks, in Utah.
The install was pretty straight forward, Teraflex has made a install video that walks the installer thru all the details. I watched the video, then went into the shop to put them on. The front end took a few hours, the rear shocks were easy, even with adding the Falcon bump stop & strike pad. There is also a roost guard for the rear shocks that bolts in place, protecting the shock shaft quite well. Rather than deal with compressing the front coil springs, removing them for the factory shocks and then installing them on the front Falcons, I choose to take them to my local 4x4 shop, Barney Brothers in Grand Junction, CO. I've had them do quite a bit of work for me and I'm always happy with their work.
I test drove the truck last night, but haven't really spent much time with the Falcons on yet. I will say that the truck and it's suspension feel so much more sporty... the truck just begs to be driven hard. The suspension is compliant and allows the truck to work, but it just feels way more planted than stock. We need to put some miles on the truck and eventually get it offroad for a real test and that will come soon enough. I'll be updating this thread as time and miles go on!
Greg@RME
Alright, first REAL offroad test for the Falcon Sport Tow/Haul shocks! I took the Ford F150 out to White Wash sand dunes in Utah, not far from Moab. The drive out was chilly and it was quite foggy on the way in. I made my way down to the big wash that runs around the dunes, aired down the tires to 20 PSI and started to feel out what the truck was capable of. The wash is wide and plenty open, but there are a few places where it's whooped out and there are decent sized transitions... you have to be cautious, to a degree. I was pushing the truck harder and harder and it was completely composed and stable and almost any speed. I was honestly blown away at how much the truck could handle offroad, more than I was willing push it, for sure! It was easy to push the truck in turns and get the rear-end to slide around and it felt totally predictable. This truck simply ROCKS bombing around offroad!
After playing in the main wash, I headed into the sand dunes and played around. Again, the truck handled everything I threw at it.... even fully extending the suspension, then compressing it fully when coming off a dune made for a comfortable ride. Bottoming out wasn't harsh, you can tell you've hit bottom but it's not a solid, jarring hit.
I worked my way around the North side of White Wash, playing around in the wet gully with quite a bit of speed. The truck again soaked up all the bumps & jumps, feeling completely composed and stable. It's amazing how well rounded this F150 is.... capable of towing, off-roading and daily driver duty. The Falcon Shocks, BFGoodrich KO2 tires and Method wheels helped totally transform it! I'm not sure how I could be any happier with the all around performance of the truck with Falcon Shocks.
D
Deleted member 9101
Guest
They sound pretty awesome! I'll definitely look into them in the future.
Greg@RME
Well, the tow test is in the books! Sooner than I expected, due to an unplanned breakdown of my JKU while driving home from work last night.
For some information and numbers... the trailer is a 16' + 2' dovetail tandem axle, I'd bet it weighs close to 2,000 #'s. My JKU is quite piggy, I'm pretty sure it weighs every bit of 5,500#'s as it sits. So we had almost 8,000 #'s behind the truck, I think that's sufficient for a proper tow test of the Falcons!
First off, I picked up the trailer empty and drove about 25 miles around town and on the freeway, at speeds up to 75 MPH. I left the shocks on their #1 position, or the normal "Soft" setting that you'd use for daily driving. With the unloaded trailer and the Soft setting, it felt great... very controlled, no trailer weight bouncing the rear of the truck around. Even on dips and bumps on the freeway at speed, the shocks allowed the springs to work, then control the bounce and stop it from continuing and upsetting the truck. This seemed like a good sign, early on!
Once we loaded the Jeep on the trailer, I set the Falcon Tow/Haul shocks to the #3 setting, "Firm" and drove about 25 miles on the freeway, then in town to get the Jeep back to my home. This was my first time towing a real load with the F150 and I started in a winding canyon with 60 MPH roads. I eased up to the speed of traffic, feeling the truck out thru the corners. The first thing I noticed was how 'tight' the rear end of the Ford felt with a load behind it. Even on dips and bumps, the rear suspension felt very controlled. Honestly, it's a little hard to put into words and describe accurately.... but it was so much better than stock shocks. The rear suspension simply felt ideal for towing.... and I never felt like I needed more dampening from the front shocks or any kind of adjustment up front to go along with the rear. The rear Falcons on the #3 Firm setting controlled the load and bumps to the point that the irregularities in the freeway weren't an issue at all.
It was honestly hard to tell the trailer was back there, as far as the truck and suspension reacting to the road and weight of the load. I've had some trucks that bounce all over the place when towing, the back-end starts to loose control over the load and it ends effecting the front-end, causing you to slow down to regain that control. That didn't happen with the Falcons at all... if anything, the amount of control with a load was very confidence inspiring. I do believe that the adjustable Falcon shocks make the F150 a towing hero, it's that big of a change.
It blows me away that a set of shocks can change a truck so drastically and increase it's performance on the road doing daily driver duty, hauling around a fairly heavy load on a trailer and then also turn the truck an offroad beast when you want to go play in the dirt. I couldn't be any happier with the Falcons, they're truly impressive.
Explorerinil
Very good write up, it’s amazing what a proper tuned suspension can do. I’ve never heard of falcons before, I got a friend with an f150 I’ll mention it to him.
Greg@RME
Thanks, I appreciate that! I think the Falcons are a game changer for the new trucks and SUV's, they really turn them into a better all around 4x4, increasing capability at all levels.
What broke on the jeep?
I'm not sure, the engine just shut off while on the freeway and wouldn't restart. Its something electrical, still isn't fixed. I'll be taking it to a shop and let them deal with it. :(
danneskjold
I am debating between these and Kings for my 2018 F150 with a Four Wheel Camper.
What tire size are you running? You mentioned 285, which I assume is a 33, but I’d like to run 35s if possible.
Did you get a new UCA? How’s the alignment without one?
Grassland
Do the rear shocks work with an add a leaf or new leaf pack?
These look like a good upgrade compared to 5100s.
I have 5165 remote reservoir shocks for the rear and am on the fence with them.
The adjustable feature seems like a good idea for the daily driver with little to no load in the bed but loaded up with a trailer or full payload on the weekend.
How do they compare price wise to some entry level icons or fox?
Greg@RME
We're running 285/70/17's, which is close to a 33" tire. I'm not sure if 35's will fit with the leveling shocks, they might but I can't say for sure.
We didn't need new UCA's, the truck aligned with no problem.
I think the rears would work with an AAL, new leaf pack all depends on if it adds lift. I'm sure the folks at Falcon shocks could tell you more. I do know that they offer longer Falcons for this same truck, I believe up to 4-6" of lift... so there are options.
I think the entry level Icons and Foxes are about the same price if not a little less (its been awhile since I looked) but if you compare build specs, you get a LOT more shock for the money with the Falcons. Look at the shock body size, shaft size, negative spring, bump stop, shock fluid, adjustable tow/haul modes, etc. You get so much more with the Falcons versus a standard shock.
We're actually down in Baja for the holidays and couldn't resist taking the Ford F150 out today and push it pretty hard on the dirt roads in the area... the Falcons on this truck are incredible at speed, the harder you push, the better they work. I've seen over 50 MPH on rough roads and the truck feels so well planted! I hit a couple of big bumps and saw a little air, but even on hits like that the truck is totally composed and soaks up the bumps with no drama.
Martinjmpr
Wiffleball Batter
Nice write up!
Question: is there any lift in the rear of the F-150? It doesn't look like it. So stock rear suspension other than the shocks?
Looks like the truck sags a bit with the jeep on the trailer. Have you considered some kind of weight distributing hitch? I finally put a WDH on our 3500lb travel trailer and it really improves both the sagging of the rear suspension as well as handling at highway speeds. The one I have is the E2 round bar type. Does not use chains which means I can back up without disconnecting it.
The E2 incorporates sway control which I really appreciated driving back from Texas in November with 30 - 40 MPH cross- and head-winds.
Joseph McCormack
