One more M416 build
wvtradbow
About ready to start the frame,I've looked all over this form on how to relocate the hand brake, an other than people saying they relocated the hand brake I couldn't find any examples. I needed to do this because all trailers need a Harbor freight tongue box an this one is no exception,so here's what I did: I'm not sure I like the position of the lever an may end up mounting it vertical not sure yet.
cemeb4dk
I relocated mine where yours is but stood it up vertically not horizontal as yours. I did have to get a turnbuckle to connect to brake lever. If yours works that way and your happy keep it. I just wonder if it's going to be a shin buster sticking out there
wvtradbow
Cemeb4dk that's my thoughts exactly,I can imagine running into that thing in the dark,but not sure what you mean by "turnbuckle",I was thinking just some sort of U channel ??
PacificNorthWestJeeper
Blissfully Lost
On my build my handbrake was 'frozen', I had to heat it to free it up and completely disassembled it then rebuilt it.
Like you, with my build my hand brake was not going to work in the original location.
I used threaded rod which you can get it in some pretty long lengths from auto and hardware stores.
Find the one that thread right into your brake assembly.
I heated up the rod to bend the ways that I needed it to and relocated the handbrake along the main beam up front.
On the ends of the rod I used that rubber dip stuff you can get at lowes to help eliminate metal on metal contact.
I had to also make a new pivot point because the original was not 'clocked' at the angle I needed (see pic) which helped me get more leverage to lock the brakes in place.
You can see where the handle is now in the pic. I like it because it is tucked out of the way and almost not visible, just looked cleaner.
Of course I ditched the original frame and went with ⅛ wall tubing for the main portions of the frame which I am very glad I did.
You are on the right track, there is no manual for fab, just keep staring at it and ideas will pop into your head.
Good job, and good luck..Trailer1a.jpgTrailer2a.jpgTrailer3a.jpgTrailer4a.jpgTrailer5a.jpgTrailer5a.jpg
wvtradbow
Well after some of these post I decided to move the brake lever ,however I couldn't put it under the tongue box because I didn't extend the tongue the way PNWJeeper did, so it would've took some work to do that . I just made a bracket an repositioned it but it's still gonna be a shin buster but I do like it positioned this way better.
wvtradbow
I also got new shocks AND just a FYI they are Monroe 59017
wvtradbow
My next move will be some sort of under carriage spare tire mount.. I would really like to see some idea's of how to do this,if any of you 416 guys got any pics...
wvtradbow
Did the inside of the tub along with the bumper an tongue box yesterday..What a nightmare that that turned into,the results wasn't too bad BUT,for some reason I couldn't get it spray right,I used 2 different guns an both just kinda "spit" instead of spray so I ended up rolling some of it an this caused it to be a more aggressive texture than I wanted plus my garage was real cold an even this morning it's still tacky..The previous owner did use some kind of liner on it already but it was maybe like rubberized undercoating or something that got pretty "gummy" when trying to prep it,But Hopefully it'll harden an turn out alright..I still have the lid to do an was going with liner Xtreeme but after this,i'm going a different route..
wvtradbow
Finished!!
wvtradbow
Just finished painting the tub. It's pretty cold but I did everything I could to get it warm enough including a little heater inside the tub an covered it with plastic to get the metal warm enough an yes the bed liner hardened up nice..I painted it with the newer Toyota color Quicksand. Even though I stripped the tub an sanded it,used epoxy primer then a filler primer,there are still visible sand marks.
wvtradbow
I feel like i'm coming down the home stretch with this build,I still have a lot more to do but I can almost see the finished trailer..I got the lid in Epoxy Primer an about got my homemade Unistrut rack built...
wvtradbow
The next pics will be of the top in some sort of black bedliner an the rack will be painted with some aluminium "dressing" around it.. I've been contemplating what to do for the rack.I have some Thule bars an rail but the more I thought about it,I kinda like the Unistrut look,I did one on my Toyota an kinda reminds me of a Prinsu rack when it finished..
wvtradbow
Doing the finishing touches on my homemade rack ,about the only thing left to do is wheels an I have to fix the lights,small problem there plus I have a couple decals to go on it..
