DIY Discada "Skottle" Cooker $65.00
jeep-N-montero
As for quality gear, older Coleman and Camp Chef stuff was well made, the newer versions almost fall apart if you just look at them wrong.
jeep-N-montero
Holy cow, those are less than $25 on amazon, might have to order 2 of them! So you can use them on a stove, over a single burner MSR, or right over an open fire? Sounds very practical.
Ovrlnd Rd
Thanks for the video! I've been thinking about making one out of a disc but this is much easier. Unfortunately I didn't see that they were available on Amazon and paid about $10 more for the one I ordered but still worth it.
WhatTheZo
Now that is so not fair, 2 hours left in the office and I'm pretty sure I burned off the salmon and quinoa I had for lunch a while ago! Do they have a cookbook for the bayou wok?
Hahahaha! Yeah I made myself hungry looking for those pictures. Sorry I don't remember if it came with a cookbook.
Sent from my Pixel 2 using Tapatalk
gunsandgearnetwork
Got mine also. I’m going to go ahead and sand mine down to a smoother surface.
I debated on that but kinda like it rough so it holds food along the sides away from the middle. If it is slick you might have a problem keeping food up along the edge away from the direct heat area. As long as it is not causing your food to stick (and mine does not) then you should be all good.
brianb2
This will be my second one. The first one I made from a $30 disc I got from a tractor supply. It’s about double the size and good for larger groups. I smoothed it out also, and it works well. I’m going to make a similar tripod stand for this one.
WhatTheZo
Nice! Yeah I had one of those from tractor supply. None of my heat sources could get it seering hot unfortunately. It does make a great fire pit for the desert!
gunsandgearnetwork
I am digging the tripod setup. Can you post some more detailed pics?
PNWav
