Alu-Cab Gen 3 Tents & Shadow Awnings in Stock
alexplb
Ok... convince me why this is better than say James Baroud that is roomier, has more windows and lighter? Both are in a similar price point and I get that one can out stuff on the roof of the tent but aside from that what makes it more "superior" ?
BDRXO
Supporting Sponsor / Approved Vendor
I'm not here to convince you of anything my friend...there are pros and cons to everything, you just need to pick what is right for you. If you are asking me what I like and appreciate about Alu-Cab tents after owning fiberglass hardshell tents for nearly 15 years, here is what I like:
Better durability and resistance to trees etc in off-camber situations
Ability to mount things to both the sides and roof via built-in T-track
Shadow Awning mounts directly to tent
None of the maintenance issues associated w/ fiberglass (you do need to maintain fiberglass or it will degrade)
Longer warranty
I think they look cooler :)
alexplb
Thanks for the input!
how does interior and comfort compare to James Baroud since price point is similar ?
BDRXO
Both will be similar although the Alu-Cab tent comes standard with 6 shoe pockets built into the roof as well as 2 reading lights and a 12v / USB charge center
alexplb
how much is the awning and does it have other brackets that one can use to mount it to a custom build camper?
BDRXO
The awnings are $1,499 and there are a variety of different mounting brackets made by Alu-Cab...so depending on your application there may be an off the shelf solution. PM me if you would like to discuss further
sonarman
There is a inner rail that the mounting brackets attach to. The outer rail can be used for attaching awning brackets or other accessories. Easy mounting with the channel you just slide brackets into position.
BDRXO
If you guys are referring to the silver tent on the green truck, that one was mounted with Alu-Cab load bars mounted to an Alu-Cab Explorer Canopy....all with out of the box hardware
BDRXO
You could just order the brackets, which may or may not work w/ your load bars. Feel free to PM me your contact info if you would like to discuss
BDRXO
Bump for new shipment arriving 3/30. We will have both Black & Silver Tents along with both LHS & RHS Awnings.
