dman93
I currently have no demand for electricity in camp except a few watts to charge my phone or headlamp. But I’m thinking of getting a 12V fridge and have started looking at options. This new Dometic battery sounds interesting; not cheap but light and small for its capacity, and I assume being LiFePo I can deep discharge it so can use most of its capacity without need for solar refresh, enough for a few days at camp perhaps. https://shop.dometic.com/store/dometic/en_US/pd/productID.5284991700
One question I have is about connections ... the specs online are pretty sparse. It lists one DC input, an Anderson SB50 gray connector, but the pictures also show a small (6mm?8mm?) coax input as well. It also says it has a 12V DC-DC charger, would this be internal (ie plug in any 12V source) or external, specifically for that coax input. Also, it implies the Anderson is for solar only ... why would that be? Finally, I don’t see any off-the-shelf MC4 to SB50 adaptors. Obviously it’s easy enough to make one up, but why do they use the SB connector when most solar accessory vendors provide MC4 to PowerPole (PP) cables. Thanks in advance ... I searched around quite a bit but haven’t found much about this battery, not about the various connector types. Although I may not need solar, I’d like to understand the path to add it at some point.
