GoalZero Yeti 400 Lithium only puts out 10.9 volts
hayhonker
finally - I just spoke to GZ and here is their solution to this problem with the lithium 1000+ Yetis not being able to run a fridge from the 12V port consistently. I used my REI dividend and will have one on Friday. I'll test it out this weekend.
http://www.goalzero.com/shop/cords-adapters/yeti-lithium-12v-regulated-cable/
It keeps adding some affiliate junk to the URL and I can't seem to get the link to work directly. Just search for 12v regulated cable
Gabex35
I'm not sure if GZ has redesigned their 12v port or which 12v cable the newer fridges come with ( I have an older 50qt arb) but keep in mind that there is a plastic reduction on the GZ side that wont allow the fridge plug to fully seat. I had to splice my ARB cable with a Blue Sea 12v plug due to the slimmer profile and it works great now. I have a Yeti 400 Lithium.
something to consider if your fridge isn't doing anything when you plug it in to 12v port.
Umbrarian
I have had the Lithium cable since it came out, it works fine.
