Multimeter recommendations
Mickey Bitsko
this won't sit well with many of you , I have used HF multi meters for years, I have one in both my vehicles in my camper and my shop.
I realize they're not necessarily for commercial use but for all my needs they are fine, @ $3.99 each hard to beat.
luthj
Engineer In Residence
They can work, until they don't. My parents had one of these on their boat. I tried using to it trace down a charging problem. Finally gave up and picked up my good personal unit. The "5$ special" meter was reading between 3-5V high! The results are pseudo random numbers, mostly dependent on how hard I tapped the back. When dealing lead acid charging systems, especially on off-grid type electrical setups, 0.2V can change battery life by more than half.
dwh
Tail-End Charlie
I had one HF meter years ago. Was a freebie coupon. Worked fine except for the +/- leads being wired backwards.
JPaul
I've gotten a few of the HF freebies, but the leads always break in short order, usually the positive...
Sent from my SM-N950U using Tapatalk
DaveInDenver
Middle Income Semi-Redneck
The great thing about cheap ones is you can buy 10 to average the reading of the 6 that work to arrive at an approximate value you can use to make a slightly better than coin toss guess if your circuit is working or not.
JPaul
Yeah, I only use them more to see if there is voltage or a short or ground issue. I have a True RMS Craftsman meter that I've had since I was a teenager (20 years now) that I use for more precise things. Just picked up one of the Uni-T 210E meters as well. Just needed it as a "precise enough" DC clamp meter.
V45W_Proto2.5
