fastening to aluminum square tubing
s.e.charles
Q1. - would I weaken the tubing less with self tapping screws or nutsert (style) machine screw anchors?
Q2. - is it better to use fewer, larger, screws, or more but smaller, for the same reason (keep strength).
thanks
CampStewart
You will get more useful answers if you specify the specs of the tubing, what you are fastening to it, and the length of overlap of the materials.
dreadlocks
If you put a hole in metal and fill it back up with metal its generally fine.. but I suppose not as good as no holes at all if strength and integrity are the upmost importance.
Alloy
No a hole is a hole is a hole it doesn't matter what type of fastern is used in the hole.
More but smaller is better for strength. In saying that the number fasteners has more to do with the material being fastned rather than item being fastned to.
kmacafee
I have used 1 by 3 inch aluminum 1/8” thick square tubing for a number of projects including a rear camper rack. Typically, I fasten everything with bolts through the tubing and have never had a failure. The tubing can compress a bit but it’s plenty strong.
slowtwitch
A hole is not a hole is not a hole and fasteners do matter.. a lot. But is it beyond the scope of this particular project?
trailscape
I tried a number of methods while building a trailer lid using square tubing from home depot and lowes.
The wall thickness also makes a big difference. I used 1/8" where I needed strength.
Self tapping screws had a tendency to fail over time or even initially. I stopped using them.
Rivnuts/nutserts work really well, but the size of the hole needed seemed messy.
In the end, I'm using a combination of rivets and 3M 5200 adhesive.
jgaz
After reading the posts above I’m not sure what type tubing you are using or what material you are fastening to it but I’ll show an example of an older project I put together.
Here I’m using 1/4” structural rivets to fasten an 1/8” thick bracket to 1x1, 1/8”wall, 6061, aluminum square tube.
This tube and brackets are going to support an interior cargo basket between the Sport Bars on my Jeep.
509323
This was the first project where I used this rivet gun. My old (30+ year) hand operated hydraulic gun gave up the ghost and wasn’t cost effective to repair.
I think this is the unit I purchased:
Tool Aid 19250 1/4" Super Duty Riveter https://www.amazon.com/dp/B0002SRG1Q/ref=cm_sw_r_cp_tai_KU.QCbRQ97AQ3
I think I bought mine at O’Rileys because I was in the middle of the project when old faithful died.
I’ve used it approx 100 times since I bought it and it has performed well.
The above unit will set rivets from 1/8” to 1/4” with minimal effort.
If money were no object, (yeah right), I would buy the air over hydraulic, Cherry brand, rivet gun that we had at work for only $1,000 or so.
The rivets I used were an aluminum, Cherry brand, 1/4” structural rivet. Sorry, I can’t tell you the exact part number because I just used some rivets of the correct length that I had in my tool box when I retired.
The exact number isn’t important to you as it’s dependent upon the specs of your application.
Houie
