Tundra vs F150
Status
Not open for further replies.
dave1014
Todd780
OverCamper
2" in the front is all the lift you need (plus some trimming). There is no decrease in articulation and the ride certainly won't be "rougher" due to tire size. A regear will fix any other "problems". Larger tires are the best way to gain ground clearance.
37s look about right on a Tundra IMO...
Those are 37's with a 2" level?
nlzmo400r
Far from a troll . The explain how over time it did worse at the exact same test it at one time did good at. Others improving shouldn’t effect the outcome of the tundra.
The scores are relative. If the best score is a 100, and the Tundra gets a 100 in 2009, then what does a truck that scored better get? 106? They cap the best at a given value and rate the rest relative to that performance.
Just because you win 14 games every year doesn’t mean you get to go to the bowl every year.
rruff
No, that's no lift at all. He claims no rub on the street, but sometimes offroad. Swaybar was removed plus some simple plastic and skidplate trimming. Don't know if he trimmed the body mount.
The "secret" is to use rims that have slightly less offset than stock. Those rims above have +50mm offset, vs stock +60. I have fat 35s on mine with +25 offset (also no lift). I had to remove flaps, trim the skidplate and some plastic, and cut the body mount, but the swaybar is fine and it doesn't rub anytime. You can fit 37s with +25 offset and little lift, just need to be a little more aggressive with the trimming.
Todd780
OverCamper
I'll have to see if I can find a pic of yours on 35's. No level or anything, hey? Interesting.
D
Deleted member 9101
Guest
I have owned 4 F150's (1990, 1991, 1997, 2017) and have had two as work trucks (2013,2015). All of them were every bit as reliable as the 2 Tundras (2002, 2012) I owned.
The nice thing about the Fords is they have a damn near indestructible 10 speed and can be rated to tow and haul more than the Tundra could ever be rated for, plus it has better brakes. The aluminum body means zero rust issues and the aftermarket support is insane.
The 5.0/2.7/3.5 are widely supported by performance parts manufacturers.... not so much with the Tundras 5.7.
D
Deleted member 9101
Guest
Have you looked at the 3.5 Ecoboost option? Better power and fuel economy than the 5.0
The 3.5 will flat out destroy any V8 1/2 ton when it comes to power. I have had both in work trucks and the 5.slow doesn't begin to compare to the 3.5 when it comes to pulling power.
toylandcruiser
So if 100 is perfect and the tundra scored 100. It’s perfect. Just because something scored a 106 doesn’t mean the score of 100 is less than what it was.
nlzmo400r
You’re not getting it. Yes 100 is always 100, but if the new ‘perfect’ is 200, then a 100 no longer looks so great does it?
toylandcruiser
You’re not either. If the test is exactly the same. The truck shouldn’t perform worse. So if it
Was safe 3 years ago I’m not all of a sudden going to die in an accident because another truck does better.
rruff
These days it's expected that you can slam into a concrete wall at 70mph (because you were texting and ran off the road) and walk away unscathed. Anything less is unacceptable... ;)
Like most official testing, the manufacturers learn to design vehicles specifically to perform for the test. That doesn't necessarily mean they are better in the real world though.
Status
jordanP13
