Unimog U500 Expedition Vehicle - 2005 -SOLD
bombermog
This Unimog may be one of the most insane Off-Road vehicles legally allowed on the road. With the fully equipped camper on the back the whole system is self sustainable for up to 2 full weeks with four passengers. You are only limited by fuel and water and it has a pump and filter system to fill fresh water on the go.
Purchased and Serviced by the ONLY certified Unimog shop in the country. http://www.terryleeenterprises.com
The camper was built by Phoenix Custom Campers. Their Lifting roof model has been tested and proven for years.
Self sustainable due to the:
  • 100 gallon clean water tank
  • 12 gallon grey water tank for the sink
  • 18 gallon grey water tank for the shower
  • 100 gallon diesel fuel tank
  • 2- 170w Zamp Solar panels on the roof
  • 1- 100 watt flat solar panel on the roof
  • Cummins diesel generator for off the grid power
Almost any terrain is possible with the:
  • Self inflation tire system (CTIS)
  • The massive tires can crawl over sand, snow, and ice.
  • Heavy duty 17,500 lb winch to pull out all the Jeeps, Hummers, Land Rovers, and a Kinetic rescue rope for Semi’s and Firetrucks that are buried down to their axles.
Inside Accessories:
  • Vinyl wood floors
  • White cabinets
  • Additional Stair Storage.
  • Fridge and freezer,
  • Full shower
  • Composting toilet and sink
  • Sink with an induction two burner cooktop.
  • Dining area is equipped with 6 seat belts, removable table that transforms into a bed.
  • Above the dining area are two hooks for hammocks. (Sleeps 2 more)
  • Stairs lead to the master loft with a California king memory foam bed,
  • Plenty of head room to relax and ports to charge your devices.
The Power:
  • Only 40,000 miles on this Unimog , built on a Mercedes engine it’s not due for it first major overhaul until 500,000 miles. There so many more adventures to be had!
  • The Automatic Transmission can also act as a semi automatic or fully manual transmission with the option of emergency gear selecting.
  • Tires: 395 x 85 R20 XZL
  • This allows you to have full control of this equipment at all times.
    • 24 forward gears
    • 16 reversing gears
    • Ability to use the exhaust brake and engine brake down steep grades.
Additional Features:
  • Bluetooth stereo
  • Roof Mounted Auxiliary Cab air conditioning unit
  • Cruise control
  • Air Ride seats
  • At the Front the winch has 75’ synthetic line and a 50” extension.
  • At the rear there is a pintle hitch and standard hitch with an extension.
  • 2- snatch block pulleys
  • 1300 lb lift gate with box “garage”
  • Kinetic rescue rope
  • CTIS
  • Only 2,000 miles since the last oil change
  • Only 20,000 miles on the current tires.
  • Simple to winterize with onboard compressor
The chassis is rated for 33,000 lbs. Fully loaded with gear, diesel, water, four people and all of their luggage you weigh in at 24,500lb, leaving plenty of room to accessorize.
This Unimog is located in Boise Idaho
$299,999
Text/Email Chandler @ 208-559-7432 or Chandler@TheMonkeyCreative.com
512107
512105512104512100512099512103512111512110
jacques bazinet
Do you have the measures : length, width, heigth with roof down an with roof up? is this the model for which you could switch the steering from left to right?
Thanks
bombermog
Thanks
Hi Jacques. the Mog is in storage right now, from memory I am within an inch or two on Dimensions. It is 8 ft. wide and 12.5 ft tall with the roof down. It is about 16ft. with the roof up. Great view up there! Yes you can change the steering quickly from left to right. Let me know if you have anymore questions.
Thanks
bombermog
Thanks
Sorry Jacques, I forgot to tell you it is about 29ft. long with the "garage" box taken off the lift and the lift stowed. About 33-34ft. with the lift down.
bombermog
Rob Pickering is the best! He knows all things Unimog and has been a huge help when I have no idea what the Mog was trying to tell me while on extended trips.
bombermog
Thank you to everyone who has been posting this elsewhere, I have a number of very interested folks planning to visit my neck of the woods soon.
