FYI, I have a 2006 F250 4x4 crew cab 6.5' bed with the the gas 5.4 motor and we also have a Lance 865. We do not tow a trailer. I weighed the truck and camper together (full tank of gas, water tank full, passengers and camping gear, etc) and it weighed 10,160 lbs. I am right up against the GVWR for my truck, but I think due to whatever options the truck has mine has a lower GVWR than some. I'm in the market for a new truck soon and it will be either a F350 or a Ram 3500. Redthies is right on track with his comments...You will ALWAYS end up heavier than you think...
No problem at all: 24”.Thanks Mike,
If it wouldn't be too much trouble... I would like to know the measurement from the bottom of the 865 to the bottom of the cabover? I've been searching dimensions for the Lance 865 but no luck on that particular measurement. I'm curious just in case I run across a flatbed that might work?
Thanks again!
I’m trying to make the same decision and I go back and forth. I think I’ve realized I want a diesel, but don’t need one. The 13 year old/170k mile 5.4 gas engine handles my camper fine, and I’ll never tow anything over 9k. I’ll keep my next truck for a long time and because of that I’ll likely buy a new one. The difference between a gas and diesel truck is about $10k, and I can fund a lot of adventures with that money. You also could lose about 800-1,000 lbs of payload capacity with a diesel.Thanks guys,
This has given me something to think about...
My next worry is if going to a 1 ton, whether or not to get a diesel. If I buy a used 1 ton with a diesel and it dies 6 months after I buy it, the $12k rebuild cost would really suck, unless I did it myself. Haven't rebuilt a motor in a long time and never a diesel. Diesel vs. Gas the age old question.
Thanks guys,
I think I may have worded it wrong? Is the 24" from the bed of the truck to the bottom of the Lance cabover? IE about the same distance as from the bed of the truck to the top of your F250 cab? I thought it might be in the 40"+ range? Thanks!No problem at all: 24”.
I’ve thought about a flatbed on our next truck, and the primary reason is for more outside storage room. I think I just need to take less “stuff” along. Please post up if you end up doing a flatbed.
My thinking as well, and less repair costs.Unless you like to burn money and expensive fuel, you don't need a desiel. The 6.2 will do just fine, for far less money. It will also have a higher load rating.
Thanks for talking me off the cliffI’m trying to make the same decision and I go back and forth. I think I’ve realized I want a diesel, but don’t need one. The 13 year old/170k mile 5.4 gas engine handles my camper fine, and I’ll never tow anything over 9k. I’ll keep my next truck for a long time and because of that I’ll likely buy a new one. The difference between a gas and diesel truck is about $10k, and I can fund a lot of adventures with that money. You also could lose about 800-1,000 lbs of payload capacity with a diesel.
