Van Compass
Update - 300 miles of mixed driving so far. Van is getting about 11 mpg, better than expected. The range is so much better with the 40 gallon tank. Was only getting 12-13mpg as a 2wd van. The speedo is correct for the tire size with the tone ring mod. The divorced Atlas transfer-case is very noticeable over 70mph. We plan to try some different bushings to reduce some of the flex the current mount has. Not sure if it will make it the gear noise worse, better or stay the same. Totally drive-able as is, but would like to try for an improvement. I wish the Transit was body on frame construction.
We are doing a drive from Post Falls, ID to Atascadero, CA starting Thursday for a wedding. Heading over to the Mammoth Lakes area Sunday night to do some exploring before heading to Overland Expo.
