Connectors and crimpers
shade
A Jokari cable knife looks like a good way to go. This is a product video. The review videos I found were annoying, but positive.
rho
Lost again
I love all the connector and crimp tool/die geekery in here. Its fantastic! Keep on crimping on! I myself just ordered a bunch of DT series stuff as I have the tools for those already. Weeee!
shade
Harbor Freight makes a pretty decent hydraulic crimper that comes with various dies.
I have one, or one of the many similar ones. It can work, but I can't say how well, since repeatability is suspect when manually gauging which die to use, and how far to crimp.
Being a tool geek and needing to do several crimps, I ordered an FTZ ratcheting crimper, which arrived today. It won't be used often, but I'll use it and share it with friends enough to justify the cost.
94Discovery
Please clarify this. Do you mean solder that works itself into the wire makes inflexible and potentially a place for the wire to crack? I know on sailboats solder has gone away in favor of crimp/heat shrink.
On one of my crimp/solder I can tell the solder wicked up the wire. I am not too concerned as this was only a proof of concept setup.
Wicking is accepted ,the maximum is 2 diameter of the wire, so it goes under the rubber and makes a solide mechanical fixture so if the wires vibrates it won’t brake the wire
DaveInDenver
Middle Income Semi-Redneck
Where did you learn that? The acceptable criteria when I was taught was wicking must stop at the insulation. That's per NASA, though, so their workmanship standards were pretty specific and connectors are almost always crimped.
I'm just curious who recommends that since the underlying reason is you don't want to move the stress point up under the insulation, away from the support of the terminal and where it can't be inspected. It's bad if the wire fatigues and the insulation is holding it together.
526665
94Discovery
I do not about aerospace standards,i will check the ipc-620 tomorrow at work and will report back remember there is class 1/2/3 ,nothing is flying or going into space and it is not medical so it class 1.
john61ct
Very low standards to call anywhere near decent.
Many AWG sizes aren't served at all by their metric dies not even close.
AWG sizes are simply not available, and would cost more than the tool. The NT and Amazon and eBay ones the same. Some even flat out lie and claim to support AWG. They don't.
Plus the hydraulics don't last long at all, make a mess.
So yes, hardly any money, but a waste for most that value their time.
kmacafee
I've had mine for 5 years and I've been able to crimp every size of cable I've ever needed. All of the dies are AWG and the hydraulics still work like new. Just lucky I guess.
DanoWall
