jonathon
I thought I’d share my GMT400 adventure. These trucks are plentiful and cheap right now, but that won’t always be the case.
Back in the beginning of 2018 it was apparent I needed a truck. We could only afford one newer vehicle so I decided to go for an early GMT400, preferably a K2500 or K3500. We had a 2017 T4R that was later sold so we could buy an Outback. I found a light duty K2500 extended cab on Craigslist and it looked straight for 210k miles. It was advertised for $3200 and had a Goodwrench L05 crate engine put in at 100k miles in 1998 and the 700r4. There was paper to back up the engine and transmission. Looking at the truck it was apparent there was a lot of deferred maintenance and poor quality repair work. The seller had replaced the starter and took out the knock sensor wire in the process. This caused a code 43 and the engine to run in limp mode. The thermal linear actuator was always engaged so he just disconnected it. The entire front end was toast too. The plus side was otherwise unmolested and the truck was clean with an intact, albeit tired, interior. It had a set of black steelies with old Michelin LTX 31’s on it. I offered $2000 and after much deliberation he took it. I still think I got a good deal.
The day I brought it home.
First obvious issue was a major vacuum leak from the evap lines. Fixed with new vacuum line.
Door roller and hinge pins next. Typical GMT400 problems.
The source of much grief. Turned out the previous owner snapped the knock sensor wire when pulling the starter. He found a broken wire and repaired it. Wrong wire! I had to run a new wire from the electronic spark control module to the sensor.
These diagrams really helped me with the code 43 and knock sensor.
I did a full tune up with plugs, wires, cap, and rotor. I also replaced the coil as it was arcing bad. AC Delco parts are a must on a TBI engine or you will eventually have issues. My EGR valve was not so great either so I replaced it with a new AC Delco part.
Then I just drove it. We went camping, day trips, forest road adventures, and did work. Long bed extra cab is just about perfect.
To be continued...
To be continued...
