Contd. Next day - drove down to Sedona, hit up the Oak Creek for some swimming and then did Broken Arrow for a totally different kind of 4x4ing.
Broken down Frontier blocking one of the busiest trails in AZ. Pink Jeep tour guys were being dicks to the guy and were super mean and upset because they "had a schedule to keep" rather than helping the guy out.
Turns out the Frontier's computer died so nothing was working, couldn't even keep the car on.
I hooked up a strap and pull him off the trail to let the convoy of Pink Jeeps by:
Then we disconnected and I was planning on leaving him there but then after speaking to him more realized what a pickle he was in. With no way to start his car he had no way to get rescued other than an expensive 4x4 tow truck which would probably have to come up all the way from Phoenix. He said he had AAA so if he could just get off the trail and back to asphalt he'd be good. Now, anyone who has done Broken Arrow knows that to get into the trail you have to go over a pretty high rock face and with no power that was going to be interesting. But we came up with a plan, I hooked back up to the rear of the truck, pulled him up a rock hill to get him turned perpendicular to the trail exit/obstacle, then rehooked up to him and pulled him from the front to the edge of the obstacle. Then I unhooked, went down off the obstacle to a safe distance, got out and pushed his vehicle down the rock face. Once he was down, I rehooked onto his front and towed him down the dirt track 1/4 mile or less to asphalt.  We've all been there or all will be there one day so help out your fellow 4x4s whenever possible, just be safe and smart.
This is the 5th time I've had to save someone. My recovery kit consists of:
4 - 3/4" D Rings (AKA Bow Shackles)
2 - 30' 18,000# snatch straps
1 - Rear Recovery Point for 2" Hitch receiver
1 - Pair of gloves
1 - Shovel
1 - Hatchet
And soon I'll be adding a winch + winch dampers (AKA winch blankets), snatch block, and hi lift jack
One of the hardest obstacles on the trail, doesn't look like much in this photo from far away but it's a 30 degree angle and most avoid it altogether. The Pink Jeep Tours just go down it, probably too much of a liability to go up it since you're just staring straight up at the sky with no ground references whatsoever. Anyways, I went down it and then turned around and went up, no sweat with the rear locker on but I also did it in my last Gen3 with just the traction control, albeit with a little more wheel spin to get going.
The hardest obstacle on the trail would be going up Devils Staircase rather than just going down which is how the trail is designed and I've never done that. I was going to do it this time, my 5th time doing the trail but first in this Montero, but earlier on a little nothing ledge that I misjudged and went off a hair to fast I hit my driver side rock slider on the ledge and it bent up and contacted the rocker. So I figured if the sliders couldn't take that baby bump I better not go up Devils Staircase until I investigated further, just in case. Probably has to do with how the Gen3 doesn't have a solid ladder frame to tie the sliders into since the sliders themselves don't look like they bent but I'm not really sure yet because I haven't taken them off for a good look.
Epic weekend is the only way to put it - so happy I finally moved to Flagstaff and have this amazing outdoors in my backyard.
And today, I got gas and found that on this last tank I got 13.4mpg which is amazing considering all of the full throttle, just shy of redline, 1st gear, 4low driving that was done at the Cinders OHV + Frontier towing and 4x4ing the next day. With just regular driving on the tank before this one I got over 17mpg which is a big improvement from when I first got Yoshi. The truck was getting 14 in mixed city driving with 31.5" Load E Nittos and the stock gearing. But now it has picked up 3 mpg with Load C 33s, 4.90s, fresh gear oil, and a tune up.
One other thing I noticed was that the car smells like unburnt gasoline when going up steep angles - turns out this is a common Gen3 problem from a fuel leak in some fuel vent pipe and there is a
factory recall for it that I'll need to get done next time I take the truck down to Phoenix.
