2001 Ford 4X4 E350 XLT Van 7.3 Turbo Diesel PRICE DROP!
mauijosh
Hello All I am a new member and thought I would share this with you in case it is up one of your alleys.
Very Rare 2001 E350 One Ton Extended Van that's Four Wheel Drive! 4WD!
Very Strong, Smooth Diesel Power, can tow 5 tons. This Thing is a beast but its also a Unicorn as it is very hard to find this combo of options and features ready to go!
Custom Built with One Ton F350 Superduty straight axles.
7.3 Turbo Diesel ( Best diesel Ford has offered known to go a million miles regularly), All options with XLT Package, power windows, power locks, power driver seat, Cruise Control front and rear heating and A/C Built in Alpine sounds system with Bluetooth, amp setup for a sub, Inverter provides 120VAC, has two pop down roof mount LCD TV screens with wireless headsets. Transfercase was replaced 10K miles ago. 230K miles
Seating for 12, benches are easily removable. Lifted with New 34" Yokohama Geolander AT tires.
Tow package with class V hitch
The conversion was done when new by Salem Kroger with leaf springs up front.
The four wheel drive works great and has never left me stuck even in N. Idaho winter.
Lots of work done in the last 4000 miles:
All new steering parts all Moog and ball joints, fresh alignment drives smooth and straight, have all receipts.
New Injection Control sensor and seals on engine, runs strong, tows great!
New HD Rotors, Calipers, Pads, Shocks, Steering Stabilizer, Injector Seals, all injectors shimmed, Injection Pressure Regulator, HPOP, Fuel Pump, Windshield.
New Glow plugs, Valve cover gaskets with new under valve cover harness.
Deleted the Exhaust Back Pressure valve. Fresh Oil Change
Tepui tent with rack available separately for an extra $1000 if you buy the van at asking price of $26,000
Located in Sandpoint, ID 83864 I can meet at Spokane Airport if that helps.
mauijosh
Dropped again!! Double Dropped
$24,000 Ready to drive anywhere you want!
4xCoffee
