What did you do to your Mitsubishi today?
PaydayGabe
So,,, can anyone explain the situation here w/photos??
What is this
"allowed extension" mean?
I've been on other forums and some have a minimum post requirement before photos can be added. I don't have Photobucket or other apps. Help please. G.
Quest4ADV
Dropped the fuel tank on my 95, it was NASTY, my filter and injectors were plugged, it would barely run. I cleaned it with Evapo-Rust, rinsed with denatured alcohol, dried with my shop vac and then rinsed again with 1 gallon of gas. I also cleaned and rebuilt the injectors. It runs 1000 times better now!
lordtrunks
camp loser
Well been working on the 95 so far arb bumper warn winch 33x10.50r15 bfg muds are on picking up rodded radiator Tuesday, arb locker twin compressor air up kit braided air line and 3.15 tcase gears sitting on the floor I think I did some other stuff too ohh I need to drink some ******** scotch at some point too
Quest4ADV
Well been working on the 95 so far arb bumper warn winch 33x10.50r15 bfg muds are on picking up rodded radiator Tuesday, arb locker twin compressor air up kit braided air line and 3.15 tcase gears sitting on the floor I think I did some other stuff too ohh I need to drink some **** scotch at some point too
Hey there, I have a 95 LS, I've heard the ARB bumper is not a "Direct Fit" what did you have to do to it to get it working?
Thanks
lordtrunks
camp loser
Here are some pics and template making process for the bumper plates
  • Like
Reactions: plh
Schitzangiggles
King of Macastan
Tore into the heater core issues. Yeah it sucks but way better than paying the local shops @ $1500 to do the job. No one really wants to do the job and I'm not going to pay a kings ransom to someone who is gonna half-ass a job they really didn't want in the first place. Going to be doing a detailed write up and a video on. How to take it apart and put back together as I found -0- videos on YouTube or the net on Gen III Montero/Pajero that wasn't hidden behind a paywall.
Sent from my Pixel 2 XL using Tapatalk
kekela
Wow !!! Good on you for taking this job on !!! It's a PITA to take apart the dash to get to it, then put it all back together.
PaydayGabe
The allowed file types for images are .jpg and .jpeg and .png and .gif .
That means if you have raw photos off a DSLR, or if you have .bmp or .jfif or some other random format they won't upload.
Thanks Shovel?. My phone/ Camera settings doesn't indicate the images file type.
Just the resolution . Odd really.
I guess no photos on this forum..
Imagination time?‍♂️. Thanks, G.
PaydayGabe
Today I disassembled the cylinder heads for further inspection and cleaning. The valves are in reasonably good condition, some carbon buildup here and there.
No biggie, , a good lapping should straighten them out fine after cleaning.
The Elephant in the room is the cam bearing surfaces. The donor engine lost a rod bearing from some type of contamination.
Which migrated up. ?‍♂️
The bore surfaces are flat but feel gritty in some spots. No gouging or burning thankfully.
My intention is to attempt to make them smooth w/a fine grade Scotchbright pad and a solvent.
This is gonna be interesting.
Piecing together the assorted parts slowly.
I scored a great Valve Spring Compressor off Amazon and recommended it highly.
Just shy of 55$ bucks and it is a beast .
From OTC (OtawanaToolCompany) otctools.com
model #4842 . Not Chinese,
Made it Taiwan. The main frame is a beefy Forged piece of Kit and the screws and cups are all solid construction.
Perfect for this application. Check it out. Could definitely be a hand-me-down tool ?.
I'll be in touch... G.
Quest4ADV
:p
HOLY CRAP, that first pic looks like a tornado came through!
Quest4ADV
Do you think these needed changing???
I have no idea how old they are. I just picked this 95' up a month ago.
V45W_Proto2.5
