Building a solar-powered off-road truck (based on a 712M Pinzgauer)
shade
I saw this elsewhere and thought I'd cross-post it here.
luthj
Engineer In Residence
With a 13kw array and good sun, you could recover 100 miles of range a day in good conditions, maybe more. I am a bit skeptical, but the possibility is there.
john61ct
Yes that's a massive array, in many areas you won't have that much space to deploy it.
100miles range on 55kWh?
Now, if only the weather cooperates.
Shading issues?
But definitely a good science experiment, I'm all for whatever helps move us off fossil fuels.
Long as people imagining making use of such today's technology "in production" are realistic about the limitations.
luthj
The pack is 85 kwhr. With reasonable driving (under 60mph) I would think 100 miles is not unreasonable. There is no AC to pull power like a Tesla, and its not going fast regardless!
DaveInDenver
Middle Income Semi-Redneck
I have a feeling this is going to demonstrate that a Pinz can carry 45 panels on top of a layer of batteries in it's cargo space. So it'll work just as long you don't need to carry anything going 100 miles a day. Not to mention you must do all your driving at night since you'll need to deploy the panel array during the day.
john61ct
The pack is 85 kwh
Charging that in a single day even in sunny weather near the equator, will require 19+kW of panelage.
If they are only **using** 70% of the bank capacity, then 13kW may be enough,
but only in sunny weather near the equator.
luthj
I was including pack limits and solar charge rates in that estimate. Obviously if they are really far from the equator that will make a difference.
shade
No doubt it's an "awareness" project. On that front, it'll probably succeed. It won't be hard to attract attention with a field of PV surrounding it.
luthj
Pioneers have to go ahead of us all. Its easy to be a critic, but inspiring people is an important task, regardless of today's feasibility. Newspapers and horse riders everywhere mocked and derided gasoline fueled vehicles. You can't bring a refinery with you! My horse can graze anywhere! :unsure:
shade
I'm fine with it, and I agree that awareness is a worthy goal. Those weren't quotation marks of derision. :)
luthj
No sarcasm noted, mostly just posting that for myself. Sometimes use engineer types are too practical. Some projects are worth it just to push the envelope.
john61ct
Yes, PR stunts can be used for Good as well as evil, publicity for potential steps forward is critical to progress
seth.c96
