Express AWD control arm options
stuntman mike
Hey gang,
I was talking to my buddy while installing my insulation this past week about my suspension lift (torsion key and shocks). I mentioned the stock control arms/ball joints could be a weak link when it comes to the upgrades that are common for these vans. He suggested I look into Cognito parts, well I used Rockauto for my parts reference and was pleasantly suprised by the options they had for lifted applications. Cognito had pretty parts, but at a performance shop price of $570/pr. The options on Rockauto have single control arms from $30-$180 that offer +2 degress if camber or adjustable +/-3 degrees of camber/caster.
I am prepping a new set of wheels and shopping for rubber. If I can get better geometry from new control arms, it could save the tires some odd wear, right? Maybe even ride better, I dunno just thinking.
I haven't seen anyone mention using different control arms. Did I miss a thread?
Scotty D
These moog arms are the ones I am planning on installing once I get back from baja
RK80826 .
Unless this thread produces something better that is
stuntman mike
I did the moog arms. Probably didnt need the extra camber adjustment as mild as the suspension upgrade was. At least they're clean.
Sent from my SM-G930V using Tapatalk
Scotty D
How are you liking that combination? Did you do a 2 or 3 inch lift?
I still have not gotten around to doing mine yet and need to order in some parts!
stuntman mike
I forgot to take measurements before the van went up on the lift, but I think it was only 2"ish. I used different torsion keys, 4/1 rear leaf springs (discovered that's all the brake lines would allow regarding travel), and the +2" bilstein 5100 shocks. 275/70-17 BFG KO2. The van was smooth before the change as OEM parts were only 4-5yrs old. If anything, I think it might be a little stiffer now. I usually keep it pretty empty, but can load up a week's worth of camping gear and a dirt bike on occasion without much change.
Scotty D
Yeah , I was able to do about 2 inches with the stock a arms but my alignment guy said the camber was maxed out.
I have heard those shocks are very stiff . I wonder how they will do on washboard.
oskarf150
