| Item | Qty | Cost | Total |
| Orion Jr BMS | 1 | $ 450 | $ 450 |
| 100AH Frey Cells | 16 | $ 100 | $ 1,600 |
| Blue Sea 7713 Contactor | 1 | $ 200 | $ 200 |
| Cell connectors/Misc wiring | 1 | $ 200 | $ 200 |
| Heating pads | 2 | $ 100 | $ 200 |
| Box materials/Insulation | 1 | $ 100 | $ 100 |
| Grand Total | $ 2,750 |
If the BMS module failed, would you be comfortable doing full-manual charge management until you could install a replacement? If so, I can see some value in a standalone heating system that would still be operable even if you had to go with manual charging. I know it's unlikely that you'd find yourself managing the system with a multimeter and a kitchen timer, but it's a possibility. Just a thought.
But IMO far superior, more flexible.
I question the "Frey" cells, what is your basis for that choice?
Also why 4P as opposed to going to a bigger size?
Orion is a well respected BMS. Include the ability to disconnect everything from cells, so can be fully isolated when unused.
Good point. If the BMS died, whatever rewiring you'd have to do to get by without out it wouldn't be made much more difficult if you had to do the same with the heaters. If the Orion is smart enough to recognize an internal fault and shut everything down, the redundancy of a standalone heating system loses some of its value.Its a consideration. Since my pack will be inside the vehicle, the heaters are most a backup. But a spare thermostat isn't expensive or large.
Or maybe 1000+, with good quality well matched cells. At 1C discharge rates, maybe not, and do stay under 0.3C charging when temps get cool.At my typical charge/discharge rates, I should be able to get 100+ cycles without any need to balance (if I stay out of the knees)
Chinese bms + arduino/esp8266/esp32/etc? Think my 60a Chinese bms has external relay output but I don’t know how to operate it as I haven’t used their official chinglish app.
but Pretty sure lithiumpcb dot com site will customize your bms if needed.
maybe I’m missing something but couldn’t a Chinese bms + arduino give you the capabilities you seek?
