Separating (composting) toilet pee tank?
Ramdough
Need to pick a route. I plan on a composting toilet that will be DIY.
Should I have a separate pee tank or run my kitchen sink, bathroom sink, and shower into the same tank?
I am thinking the grey water tank will be less likely to get as nasty without pee in it.
What do you think?
AbleGuy
Officious Intermeddler
Should I run my kitchen sink, bathroom sink, and shower into the same tank [as my pee tank]?
yuck, just....yuck!
But if you do that, consider making sure you have a "P" trap in the pipes for the sinks and shower drains to keep the smells from coming into your camper's interior.
Ramdough
yuck, just....yuck!
P traps on everything will be used.
Ramdough
Nothing like first hand experience.
Collect pee in a mason jar, collect greywater in another and third, collect a mixture. In a week or so, discover which is worse.
Yeah......that would tell me something. I would prefer to have someone else lead the charge, but I guess that could be a fall back plan.
I would imagine someone here would know the answer already.
The Artisan
Have not built mine yet but since am recycling my sink and shower water, I will be using this. My compost is diy, I will have a funnel that acts as a urinal
john61ct
Question is, when in a situation where you can't / don't want to just dispose of the small quantities of urine as they are collected, accumulating say 5+ gallons between disposal events,
will you keep your urine "pure", segregated from the grey water also collected during that time,
or combine the two?
javajoe79
Fabricator
Separate. I don’t think you need tons of urine storage. Make it easy to dump or remove a small tank to pour out. Depending on where you camp it can also go to ground
  • Like
Reactions: WVI
javajoe79
Fabricator
What kind of diy compost setup are you doing? I’m going to build mine, just not sure how complicated I’ll make it. Thinking just a simple stirring mechanism and a tiny fan. I’ve been planning on a small pee tank under the truck with a ball valve drain so I can just leave it open where appropriate or keep closed when not.
Ramdough
I plan to buy a separator and have a 5 gallon bucket. Not sure on a mixer or not.
If I combine the liquids, I might plumb the sinks through the same p trap so it is always flushed with water after using the restroom.
