plumber mike
The DEF tank makes a larger tank in the Diesel a no go. I suppose if you deleted, you could put in a larger tank that came in the 2010 era trucks. My 2017 Ram 2500 CTD only has a 26 gallon tank.
The rubber mat keeps moisture from getting down to the factory installed mouse nest material. When that stuff gets wet, it stays wet, and corrosion begins. No carpet for this guy. No floor mats either. They just keep the carpet nice, and as mentioned, slip around on the rubber mat. JMO YMMV
