CrazyDrei
Space Monkey
Finally had some time to play with the Avi.
Got the Avalanche started, drained the fuel and put 5 gallons of new fuel. Fired right up but ran rough. I'm sure it will need spark plugs and an oil change for it to run smooth, but that's a project for another day.
Time to start taking it apart. First was the air box and mass airflow sensor. Surprisingly the air filter was really clean. Right front fender has some rust damage, nothing special for a New England truck, will clean up the hole, couple coats of pain and then a fender flare to go over the rust.
Headlights came out and fan shroud top trim piece. One of the headlight mounting brackets was broken but once again surprisingly all the bulbs still work. Same bulbs as my 2000 Suburban.
I was excited and knew that the bumper would have to come off anyway, but I could not get to the headlight support frame without removing the bumper first. Previous owner was in a low speed fender bender, bent drivers side lower bumper support.
Bumper is off, headlight support is off. There are several trim and support pieces on this truck that I have never seen before because I have never played with a truck with cladding or Z71 trim packages. On a side note I can see why so many people are having trouble with their transmissions, that little itsy bitsy sad excuse of a cooler is a two line transmission fluid cooler, it's so tiny and positioned where it doesn't get enough airflow to do anything. I have a towing package on my Suburban which came with a much larger transmission cooler that mounts on the "A" frame in front of AC condenser and cools the transmission oil much more effectively.
Next step is to take off the hood and fenders. Rip the frond end of the Suburban apart and start bolting on Avalanche pieces to the Sub.
Stay tuned for more shenanigans!
