2010 Sprinter RV. Lifted 4.5”. 920w Solar. 63gal H2o. 17mpg. Ready for Full Time Travel.-- SOLD!!
montypower
Adventure Time!
This is the ULTIMATE long term travel vehicle…ideal for recreational enthusiasts who want an exterior GARAGE! Easily remain “off grid” for 2-4 weeks with ample water and electrical power. Plus beds for 6 adults. All with an average fuel economy of 17mpg! Turn key rig.
2010 Winnebago View 24J. 78k Miles. Service Records. $30k in upgrades!
VIN # WDXPF445389367453
Price: SOLD!
Located:
Contact:
Optional Items:
Custom Motorcycle Carrier w/ byfold ramp - $450
Kawasaki Z125 motorcycle (knobby tires, lower gears, upgraded seat) ~2k miles - $2,400
I’ve loved Mercedes Sprinter Chassis for years! They are durable, reliable and economical. However, the cost kept me away. A decent used van and conversion easily can run $60k and a ton of work. This is where the Winnebago RV shines. While the new MSRP is $159k, used is much more cost effective. We purchased the Winnebago View 2.5 years ago and have thoroughly enjoyed it. I’ve had experience of many highly modified 4x4 vehicles Tacoma, 4runner, Montero, Tundra… with “overland” setups including 2 styles roof tents, interior sleeping platforms and Four Wheel Camper. You always trade off comfort for capability. This modified version of the View offers sufficient capability to camp off grind nearly anywhere, reach any trail head and explore; all while enjoying non compromised comfort.
The Winnebago View chassis is different than most RVs. It’s build more “structural”. Full welded aluminum sidewalls and roof. The floor, walls and roof are integrally connected with interlocking joints. Fiberglass walls with block insulation. Crowned one piece fiberglass roof that wraps over the sides (leak prevention). The body doesn’t twist or distort when traveling on rough uneven roads. We’ve hung the front tire 2ft in the air and the chassis was rigid and stable.
Chassis Specs:
Mercedes 3.0L Diesel – 5 Speed with Tip Shift
180 AMP Alternator
Axle Gears: 3.923
Trailer Hitch: 5k / 500lb tongue weight w/ 7 pin connector
Length: 24.5ft
Wheelbase: 170in
Turning Radius: 47FT (nothing turns as tight for comparison Sportsmobile 140" WB is about 50FT)
GAWR Front/Rear: 7,720lbs/4,410lbs
Exterior Height: ~11ft 3in
Exterior Width: 7ft 6in (90”)
Interior Height: 6ft 8in
Fresh Water Capacity: 63 Gallons (35 Gallons + 28 Gallon 2nd Tank)
Black Water (poop tank): 31 Gallon
Gray Water: 38 Gallon
Propane Gas (LP): 18 Gallon
Heating: 25,000 BTU Forced Air
Water Heater: 6 Gallon Gas
Stove: 3 Burner range top + hood vent
Solar: 920 Watts
Battery: Lifeline AGM 400 AMP HR
Features + Optional Equipment:
Espar Diesel Coolant Heater
Full Body Paint (not just decals - $6k upgrade)
Hydraulic Self Leveling Jacks ($5k upgrade) – Great for rotating tires!
Power Windows/Locks/Mirrors
Remote Keyless Entry (locks/unlocks coach door too)
Automatic entry door steps
Leather seats (adjustable lumbar + height) “butter soft”
LCD Radio w/ Backup Camera + Aux Input
Fog Lights (bright)
Dual Front Swivel Seats
Windshield Blinds
House/Chassis Battery Combiner switch
Skylight Roof Vent
Bathroom Vent Fan
Acrylic Powered Patio Awning w/ metal wrap
Exterior shower/wash station
Push button cabinet door latches
Engine:
Service record receipts from 2015 @ 39k miles to present. Properly serviced at recommended intervals.
ScanGauge II (display engine details) : coolant temp, transmission temp, engine load, fuel usage
GreenEco Diesel Tune + CB Engineering DPF pipe. Increases responsiveness + power + LSD compatible (international fuel ready).
Transmission:
PML Deep Transmission Pan (cast + cooling fins) increases fluid capacity by 2qts.
IPT (Import Performance Transmission) Valve Body Mod (similar to shift kit) faster shifting.
OEM Transmission Electrical Conductor Plate, Transmission Filter, Pilot Bushing, Dip Stick
Tru-Cool Transmission Cooler 4589 (24k GVWR)
Suspension:
VanCompass 2” Lift (installed by VanCompass).
Agile Offroad Complete Suspension ~2-2.5” Lift (installed by Agile Offroad): Front Coil Over Conversion, Fox 2.5” Commercial Tuned Rear Shocks, Extended Brake Lines, Custom Replacement Rear Leaf Spring pack 7,500lb load.
Tires + Air:
Goodyear Duratrac 31” Snowflake Rated Tires – Full set including spare (7 tires)
Security Chain Z6 – Snow Chains (new)
Crossfire Dual Tire Pressure Equalization System
Motorsport Tech 2.5” Dually Wheel Spacers
Vesafe TPMS Wireless Color (tire pressure monitor system)
Accu-Gage Tire Pressure Gauge up to 100psi
Tru-Flate Tire Air Down Tools (air down 4 tires at once)
ARB CKMTA12 Dual Air Compressor, Manifold Kit + Tire Air Hose Kit
Electrical System:
AM Solar (Springfield, OR) installed. Dual Lifeline 400Ah 6v Batteries. 920W Solar (4x180w + 2x100w panels). Victron MPPT 85Amp controller. Victron Battery Monitor. Has wall mount monitors for battery and solar + Bluetooth phone connection. Separate circuit breaker for ARB Air Compressor. Slide has separate fuse panel for: fridge, freezer, (3) 12v Sockets (charging laptop), (4) USB 2.1amp charge ports. Additional (2) USB 2.1amp charge ports by entry door. (1) 12v socket in coat closet. 400W Power Inverter. Maxxair Fan. LED interior lights (very bright + low energy draw). weBoost Cell Phone Booster.
Fridge:
Isotherm Cruise 195 Fridge/Freezer. Danfoss compressor (BD35F). DC or AC Powered.
Water System:
Additional 28 Gallon Tank w/ Gravity Fill + Shut Off Valve
50ft Flexzilla Water Fill Hose (lead free) + Camco 4ft Hose
Water Fill Filters: Sediment Filter + .5 Micron Filter (cysts, giardia, cryptosporidium)
Under Sink Filter: Ceramic silver impregnated (chlorine, VOCs, MTBE, Lead, Mercury, Asbestos, Arsenic, Floride and more.
Shurflow 3.0 GPM Revolution Pump w/ Accumulator
Faucet: Filtered Water Fill at sink
Delta: Built In Soap Dispenser
Rear Bed + Garage:
Bed platform w/ ladder. Comfy 6” foam mattress. Exterior Garage cabinet enclosed.
Cosmetic + Function:
New Front Headlights (replaced faded ones)
Tinted Windows – Ceramic heat rejection (front + dinette windows)
Strut on Entry Door (self open + holds door open)
Sewer Hoses (2)
Further Interest??
Check out the FAQ Document!
MPG Log
cliffi
A few questions:
1. Pictures with the slide open? Any issues with functioning in rain?
2. Max weight capacity of the motorcycle carrier is?
3. The space under the double bed at the back looks unfinished and open to a tank - more information on this please.
Thanks!
montypower
Adventure Time!
A few questions:
Thanks!
1. Will update later today with slide open pictures. No issues functioning in the rain open/closed. It is one of the better designed slides with cover awning.
2. Moto carrier is custom built (cost about $900) so no weight capacity. It bolts to factory hitch rated at 500lb load. It also has 2 side connections that bolt to extensions welded to the hitch/frame (no wobble). It's rather stout. It was designed around the motorcycle Kawasaki Z125 (Honda Grom should fit). Tray could possibly modified for longer/larger moto. I'll see about shooting a video of how it works.
3. The original bed location was at the cabinet height and hinged up to access storage area below. We raised the bed (added ladder) to allow additional storage height in the exterior "garage" compartment (space for 2 mountain bikes). It also allowed the exterior compartment to be enclosed. Bed platform height could be changed depending on desired uses. The exterior garage was the primary reason for choosing this RV. That was the primary feature we wanted while considering building a Sprinter cargo van (exterior under bed gear storage). The RV was an easy choice at it is built much better than van conversions and spacious (not confined feeling inside as vans are).
Is there any additional detail that would be helpful?
Kess
Love the bike garage. Being able to carry bikes is a prime consideration for me. Have you used it for cold winter camping? Is it comfortable and warm? Skiing use is another important consideration.
Thanks!
Gary
montypower
Adventure Time!
Thanks!
Gary
Hey Gary -
It is rather ideal for bikes. Advertising your expensive gear outside the vehicle is less good... And out of the weather!
We've been in sub freezing and snow on several occasions. It does alright... We have reflectix to cover all the windows which is helpful (good for heat too). The 25k btu furnace has no trouble heating things up. But not ideal for maintaining temperature... we removed the coach radio by the entry door with the intention of installing this: http://www.ventedcatheater.com/
The vented cat heater has nearly zero power draw, low fuel usage and without condensation or co2 issues (like all other cat style heaters). I think it would be ideal to quietly maintain temperature after the big furnace heats the space up. I'd definitely look into this opinion if snow camping was a planned activity.
Bonus. The Sprinter has an Espar diesel coolant heater. It will heat the motor very quickly in the coldest temperatures... the front cabin heater easily heats the entire space as well. Engine at idle burns less than 1 quart of fuel per hour at idle (.18/GPH).
Also, water tanks are inside (no issues there). Exterior tanks may need some antifreeze dumped in or insulation if using in extreme temperatures. Wasn't an issue for us.
Hope that helps!
-Peter
montypower
Adventure Time!
Your running dura tracs up front..is this 4wd?
Rear drive. Duratrac tires all around.
We purchased it with the intent of converting to 4WD. Had time scheduled with WhiteFeather for the conversion $25-30k. After reading some of the "issues" the conversion caused we decided to use the RV first and modify if/as needed. We found there was nowhere realistic to drive the RV that it wouldn't go (won't be on trails or rock crawling). The traction control works very well to limit wheel slippage. The dually tires carry most of the load so it has excellent traction. The front tires will lift off the ground long before the rear gives up traction. The skinny tires (stock 31" size) connect well in the snow and slippery conditions - Duratracs are snowflake rated. Clearance was the biggest issue. This was addressed with the improved suspension which also improved the handling.
The dually tires have a 2.5" wheel spacer between them which helps improve stability. It also nearly eliminates the likelihood of rocks getting caught between the tires. Flotation is great in sand/washes with the tires aired down. The dually tires really help there too.
crostopher
