FWIW - I have had both slide in and a flatbed camper on a flatbed.  Both Hallmark.  The slide in had 9'-6" floor and the new flatbed model is 8' long.  There is so much more useable space and open floor on the 8' model you wouldn't think it was smaller.  Having the side storage was great but it just meant I hauled more stuff.  Maximize your under bed storage instead of giving up floor space in the camper.  5S your tools and gear to figure out what you really need to haul.  Stick with the flatbed model.
Also, Hallmark vs. FWC pricing.  I priced both before I purchased my Hallmark.  By the time I got what I wanted they were pretty comperable and I honestly think the Hallmark is a more solid build with the fiberglass panels. (Lots of FWC fans here so I suspect I will catch some flack for that)
Solar: I recommend you talk to AM Solar in Springfield.  They sold me some "seconds"  panels that had very slight cosmetic flaws and they have worked very well.  I also purchased Victron solar controller and BMS through them.  I did Battle Born Lithium batteries and the system has worked extremely well.  The other thing to watch if you choose to go to Li batteries is make sure that the charge controller in your camper is for Li and not Lead batteries.  It will make a big difference in how much charge you get when you are plugged in to shore power.
Last but by far not least:  Make sure you know the distance from the flatbed deck to the top of cab of your truck.  It will be different than a pickup bed since there is structure to the flatbed and you may or may not have a hump in the chassis.  It may be that a pickup bed sits lower than your flatbed so you can have some room between the cab roof and the bottom of the camper overhang if its sized for a pickup. Hallmark has that dialed in and have created extra storage under the mattress to utilize that space.
ps.  Before you hand that cash over on what ever flatbed you purchase pull a tape from corner to corner and make sure its square and the sides are parallel.  Don't ask me why...just do it.
