Parts list,
dubs chops
OK guys, I am putting together a parts list for my aluminum Gladiator camper. It will be 3/16” aluminum plate seal welded with TIG.
Question is, What insulation should I use for the inside? I am considering the Blue home insulation you can pick up at lowes. Any thoughts?
Here are some of the parts I am considering.
https://teardroptrailers.net/collections/windows-doors/products/stargazer-window
https://www.ebay.com/itm/RV-camper-Teardrop-Cargo-VerticalTrailer-Window-1-New-12-x-22x-1-1-2-Wall/352811083278?_trkparms=ispr=1&hash=item52252de60e:g:W6sAAOSwBx1dk6Ar&enc=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&checksum=352811083278056026f67e8e4c5198f2318fa3d24528
https://www.ebay.com/itm/Fan-Tastic...478833?hash=item4699d36571:g:q60AAOSwiHRbmUw7
here is my mockup in cardboard lol.
billiebob
ouch, $384.00 for a door !!! mine were under $50 for 2, doors and 2, windows with the hardware
Teardropper
I would suggest you buy the door directly from Vintage Technologies (that's the eBay seller with the door) so you can order the proper depth trim ring based on your wall thickness.
The window doesn't mention an internal trim ring so again, I'd got with VT. They are a good family run business.
I have built my own doors. With the hardware and window, they were still close to $200 apiece and a lot of work.
And yes, you need to insulate your box or moisture will condensate like crazy inside.
Tony
dubs chops
Tony
What insulation are you using? I am assuming some sort of closed cell?
Teardropper
That's 2" XPS foam board. For the walls and floor, I used 3/4" polyisocyanurate. I used the poly because that's the only 3/4" foam board I could find and was damn happy to find it.
Tony
iStan814
