2016 Chevy Silverado LTZ Z71
buellconvert
I don't know if you've heard anything about the leaking 3rd brake light on these trucks, but it's definitely for real, i just noticed a small telltale mark on the headliner right below the light and pulled it off to find the gasket dried out and comprised at the top end, I ordered a replacement gasket and applied a small bead of sealant along the top edge of the gasket to hopefully help ensure no further issues. If you haven't looked at yours yet, definitely keep an eye on it!
Sent from my moto e6 using Tapatalk
D45
Yes I already documented mine was leaking and the housing was full of water
The mounting screws need to be sealed also
D45
This weekend I'll swap manifold and install the ported one
Then I'll look for a deal on the exhaust I want
D45
I am still highly considering the Zone 1.5" body lift with a 2" leveling kit
What is the size of the stock rear leaf spring block on these trucks?
buellconvert
I feel like an idiot not realizing I'd already seen your comment on that earlier...
D45
Custom Splice sells a nice hitch shackle adapter
I've been using one for years on my past 3 trucks and it's held up great
I just installed it on the Silverado
D45
These trucks seem popular with a ton of parts and accessories available......but why doesn't Mag Hytec make a rear diff cover for them?
D45
For the rear axle, if you have the 5.3 or 6.2 V8s, its 2.75 quarts
Rear axle uses the 75W85
The front axle is 1.51 quarts.
Front axle uses 75W90
buellconvert
I actually just ordered Amsoil gear oil last night at work to change mine out, i am just over 50k miles and figure it's a perfect time... going to swap the transfer case at the same time, with atf of course
Sent from my Moto E (4) Plus using Tapatalk
D45
Ported intake manifold was swapped in today...…….I will try it out tomorrow
Easy swap, just took a long time......I was not in a rush and it took me 3 hours with some breaks
Houie
